Initially, the Electron connected just fine for a full week, regularly coming out of deep sleep mode. Then, after being in deep sleep mode for 3 days straight, it now will no longer connect anymore. The firmware looks something like this:
#include "cellular_hal.h"
STARTUP(cellular_credentials_set("hologram", "", "", NULL));
int tinkerDigitalRead(String pin);
int tinkerDigitalWrite(String command);
int tinkerAnalogRead(String pin);
int tinkerAnalogWrite(String command);
Nothing special happens when the device enters deep sleep. I'll continue to monitor it, but it really is puzzling to me how last week it could go half a day in deep sleep and still connect just fine, but now it will just refuse to do so. Data-limit hasn't been reached either. I've reset the device a couple of times now, and also flashed the firmware a few times again, but it seems that I need to go through the setup process again before it'll work again.
case SLEEP:
Serial.println("going to sleep now...");
delay(500);
System.sleep(SLEEP_MODE_DEEP, 86400);
break;
Also if you wonder, reading this made me believe that deep sleep clears the configuration in the UBLOX RAM. However, as I mentioned it worked before while coming out of Deep sleep, so I don't think it's very relevant to my problem.
