I’m stuck on something, hopefully simple…
If I was not interested in receiving SMS’s or responses, but just wanted to to send an sms from my Electron to my phone (using a 3rd party SIM), what would be the simplest code?
From krvarma’s post, the simple format for a direct sms should be “AT+CMGS=”"<129/145><ctrl+z>"
As a noob, I’m guessing that the implementation might look like this:
const char* phNum = “0427473xxx”;
Thanks for the quick response! I tried the country code and dropping the leading zero, both with the “129” local formatted number and the “145” ISDN international formatted number. Neither work. I also tried replacing the \r\n carriage return for the ascii equivalent (0x0D), but also no result. Any other ideas?
Thanks heaps! That was very helpful and with a little experimentation, it works! For anyone else interested, my slightly simpler implementation is:
const char* phNum = "0427473xxx";
const char* msg = "Test message";
int ret;
Serial.begin(115200);
ret = Cellular.command("AT+CMGF=1\r\n");
Serial.print("Return from message format = ");
Serial.println(ret);
ret = Cellular.command("AT+CMGS=\"%s%s\",129\r\n",(phNum[0] != '+') ? "+" : "", phNum); //
Serial.print("Return from phNum send = ");
ret = Cellular.command("%s\x1a", msg);
Serial.print("Return from message send = ");
I now know Cellular.command returns a response (whether I like it or not!) and this has to be anticipated in the code. Also, after playing with the formatting inside the Cellular.command brackets it is clear to me that the formatting requirement is VERY particular. All those funny characters do seem to be necessary.
I’ve been trying to understand what they do, esp in the line:
I haven’t found any answers yet. Can anyone give me some pointers?
These “funny” characters are well known to people familiar with printf()
If you want to successfully understand the syntax of that you need to look at this http://www.cplusplus.com/reference/cstdio/printf/
to get the string returned via USB (mark the f in printlnf() which uses the printf formatting).
BTW, one thing your inital attempt was missing were the embedded double quotes (\") in the string - they are required. The code highliting of the snippets wrapped in the proper formating tags ( ``` ) does reveal which double quotes are embedded and which are delimiting the string.
