Hello,
I have some problems with my code. I try to send a buffer from Electron to my server with TCPClient. Here is the code on the Electron :
const size_t bufSize = 8;
unsigned char buf[bufSize];
for(size_t i = 0; i < bufSize; i++) {
buf[i] = i;
client.write(buf, bufSize); // or client.write(&buf[0], bufSize)
And I try to get the buffer on my server with a Python script :
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind((TCP_IP, TCP_PORT))
s.listen(1)
conn, addr = s.accept()
data = conn.recv(BUFFER_SIZE)
print data
But all I get on my terminal is : > PuTTY
I don’t receive any data.
Does anybody know why, or had the same problem ?
Thanks for your answer !
