Can someone give me an idea of the space available for the user program on the Electron, both flash and ram please. I note the data sheet says 128K flash but is this all available? What ram is left over for the user program after the system takes its share?
If you build a sketch (with Build or CLI) you will get a memory usage report including a percentage of how much you’ve used.
like this
Output of arm-none-eabi-size:
text data bss dec hex
24828 176 1524 26528 67
In a nutshell:
Flash used 25004 / 110592 22.6 %
RAM used 1700 / 20480 8.3 %
@ScruffR, I believe the stats on Build/CLI are not showing correctly. The Photon and Electron have about 60-80K of available RAM and 128K of flash.
Huh? I thought that was an old bug that was already dealt with - should have checked the figures and not rely on the self-healing powers of Build
How can get my actual RAM usage?
Is there a fix for the “old bug” that ScruffR mentioned?
MY BUILD VERIFY OUTPUT:
23580 180 884 24644 6044
In a nutshell:
Flash used 23760 / 110592 21.5 %
RAM used 1064 / 20480 5.2 % <<<<<<<<<<<<<<<<<< Is 20480 inaccurate?
