I’m using a Sparkfun wind station and I would like to installt it in my roof. The problem is the energy. The device is solar power and will be operative twice per hour.
I wrote an script, but did not wake up, anyone could help to me?
Thank’s
STARTUP(System.enableFeature(FEATURE_RETAINED_MEMORY));
SYSTEM_MODE(SEMI_AUTOMATIC)
SYSTEM_THREAD(ENABLED)
#include <Adafruit_BME280.h>
#include <SparkFun_Photon_Weather_Shield_Library.h>
#include <math.h>
#define BME_SCK D4
Adafruit_BME280 bme; // I2C
// Each time we loop through the main loop, we check to see if it's time to capture the sensor readings
unsigned int sensorCapturePeriod = 100;
unsigned int timeNextSensorReading;
// Each time we loop through the main loop, we check to see if it's time to publish the data we've collected
unsigned int publishPeriod = 90000;
unsigned int timeNextPublish;
const int sleepPeriode = 30 * 60; // 2 minutes sleep time
initializeTekphumidityAndPressure();
initializeRainGauge();
initializeAnemometer();
initializeWindVane();
bme.begin();
// Schedule the next sensor reading and publish events
timeNextSensorReading = millis() + sensorCapturePeriod;
timeNextPublish = millis() + publishPeriod;
// Capture any sensors that need to be polled (temp, humidity, pressure, wind vane)
// The rain and wind speed sensors use interrupts, and so data is collected "in the background"
if(timeNextSensorReading <= millis()) {
captureTekphumidityPressure();
captureWindVane();
// Publish the data collected to Particle
if(timeNextPublish <= millis()) {
// Variables from values read
float wstempC = getAndResetTempF();
float wshumidityRH = getAndResetHumidityRH();
float wspressureHPa = getAndResetPressurePascals() / 100.0;
float rainmm = getAndResetRainInches()*25.4;
float gustKPH;
float windKPH = (getAndResetAnemometerkph(&gustKPH))*1.609;
float knots = windKPH*0.5399;
float windDegrees = getAndResetWindVaneDegrees();
float bmetempC = bme.readTemperature();
float bmehum = (bme.readPressure() / 100.0F);
float bmepress =bme.readHumidity();
/////////////////////////Battery level Reading/////////////////////////
FuelGauge fuel;
float batt;
batt = fuel.getVCell();
float battp = fuel.getSoC();
// Preparing the values to String
String Stemp = String(bmetempC);
String Spress = String(bmehum); //String(press);
String Shum = String(bmepress); //String(hum);
//SI1145
String Svis = String("");//String(UVvis);
String SUV = String("");//String(UVindex);
//SHT10
String Stempsoil1 =String("");//String(tempsoil);
String Shumsoil1 =String("");//String(humsoil);
String Stempsoil2 =String("");//String("");
String Shumsoil2 =String("");//String("");
//Battery
String Sbatt = String(batt);
String Sbattp = String(battp);
//Water Mark
String Ssoil1 = String("");//String(WMValue1);
String Ssoilp1 = String("");//String(WMValueP1);
String Ssoil2 = String("");//String(WMValue2);
String Ssoilp2 = String("");//String(WMValueP2);
//Decagon leaf
String Sleaf1 = String("");//String(leaf1);
String Sleafp1 = String("");//String(leafP1);
String Sleaf2 = String("");//String(leaf2);
String Sleafp2 = String("");//String(leafP2);
//Capacitive
String Scapacv1 = String("");//String(capacitive1);
String Scapacp1 = String("");//String(capacitive1P);
String Scapacv2 = String("");//String(capacitive2);
String Scapacp2 = String("");//String(capacitive2P);
//Sparkfun Weather station
String SPKtemp = String(wstempC);
String SPKhum = String(wshumidityRH);
String SPKpress = String(wspressureHPa);
String SPKwind =String(windKPH);
String SPKdegrees =String(windDegrees);
String SPKrain =String(rainmm);
String SPKgust =String(gustKPH);
String SPKknots =String(knots);
//Ulatracker
String UBXamb = String("");//String(tempeatureFresh);
String UBXfrozen = String("");//String(temperatureFrozen);
Particle.connect();
if (waitFor(Particle.connected, 300000 ))
{ // proceede only if a connection could be established within 60 seconds
//Building JSON
String dest = "{";
if(Spress.length()>0){ dest = dest + "\"5\":\""+ Stemp +"\",";}
if(Spress.length()>0){ dest = dest + "\"6\":\""+ Spress +"\",";}
if(Shum.length()>0){ dest = dest + "\"7\":\""+ Shum +"\",";}
if(SPKtemp.length()>0){ dest = dest + "\"28\":\""+ SPKtemp +"\",";}
if(SPKhum.length()>0){ dest = dest + "\"29\":\""+ SPKhum +"\",";}
if(SPKpress.length()>0){ dest = dest + "\"30\":\""+ SPKpress +"\",";}
if(SPKrain.length()>0){ dest = dest + "\"31\":\""+ SPKrain +"\",";}
if(SPKgust.length()>0){ dest = dest + "\"32\":\""+ SPKgust +"\",";}
if(SPKwind.length()>0){ dest = dest + "\"33\":\""+ SPKwind +"\",";}
if(SPKknots.length()>0){ dest = dest + "\"34\":\""+ SPKknots +"\",";}
if(SPKdegrees.length()>0){ dest = dest + "\"35\":\""+ SPKdegrees +"\",";}
Particle.publish("test",dest ,60,PRIVATE);
//delay(30000);
System.sleep(SLEEP_MODE_DEEP, sleepPeriode, SLEEP_NETWORK_STANDBY); //Sleep a while to save battery
Weather sensor;
void initializeTekphumidityAndPressure() {
//Initialize the I2C sensors and ping them
sensor.begin();
//Set to Barometer Mode
sensor.setModeBarometer();
// Set Oversample rate
sensor.setOversampleRate(7);
//Necessary register calls to enble temp, baro and alt
sensor.enableEventFlags();
return;
float wshumidityRHTotal = 0.0;
unsigned int wshumidityRHReadingCount = 0;
float wstempCTotal = 0.0;
unsigned int wstempCReadingCount = 0;
float pressurePascalsTotal = 0.0;
unsigned int pressurePascalsReadingCount = 0;
void captureTekphumidityPressure() {
// Read the humidity and pressure sensors, and update the running average
// The running (mean) average is maintained by keeping a running sum of the observations,
// and a count of the number of observations
// Measure Relative Humidity from the HTU21D or Si7021
float wshumidityRH = sensor.getRH();
//If the result is reasonable, add it to the running mean
if(wshumidityRH > 0 && wshumidityRH < 105) // It's theoretically possible to get supersaturation humidity levels over 100%
// Add the observation to the running sum, and increment the number of observations
wshumidityRHTotal += wshumidityRH;
wshumidityRHReadingCount++;
// Measure Temperature from the HTU21D or Si7021
// Temperature is measured every time RH is requested.
// It is faster, therefore, to read it from previous RH
// measurement with getTemp() instead with readTemp()
if(wstempC > -50 && wstempC < 150)
wstempCTotal += wstempC;
wstempCReadingCount++;
//Measure Pressure from the MPL3115A2
float pressurePascals = sensor.readPressure();
// What's reasonable? http://findanswers.noaa.gov/noaa.answers/consumer/kbdetail.asp?kbid=544
if(pressurePascals > 80000 && pressurePascals < 110000)
pressurePascalsTotal += pressurePascals;
pressurePascalsReadingCount++;
return;
float getAndResetTempF()
if(wstempCReadingCount == 0) {
return 0;
float result = (wstempCTotal/float(wstempCReadingCount))-32/1.8;
wstempCTotal = 0.0;
return result;
float getAndResetHumidityRH()
if(wshumidityRHReadingCount == 0) {
return 0;
float result = wshumidityRHTotal/float(wshumidityRHReadingCount);
return result;
float getAndResetPressurePascals()
if(pressurePascalsReadingCount == 0) {
return 0;
float result = pressurePascalsTotal/float(pressurePascalsReadingCount);
return result;
// Rain Guage
int RainPin = D2;
volatile unsigned int rainEventCount;
unsigned int lastRainEvent;
float RainScaleInches = 0.011; // Each pulse is .011 inches of rain
void initializeRainGauge() {
pinMode(RainPin, INPUT_PULLUP);
rainEventCount = 0;
lastRainEvent = 0;
attachInterrupt(RainPin, handleRainEvent, FALLING);
return;
void handleRainEvent() {
// Count rain gauge bucket tips as they occur
// Activated by the magnet and reed switch in the rain gauge, attached to input D2
unsigned int timeRainEvent = millis(); // grab current time
// ignore switch-bounce glitches less than 10mS after initial edge
if(timeRainEvent - lastRainEvent < 10) {
return;
rainEventCount++; //Increase this minute's amount of rain
lastRainEvent = timeRainEvent; // set up for next event
float getAndResetRainInches()
float result = RainScaleInches * float(rainEventCount);
rainEventCount = 0;
return result;
// Wind Speed (Anemometer)
// The Anemometer generates a frequency relative to the windspeed. 1Hz: 1.492kph, 2Hz: 2.984kph, etc.
// We measure the average period (elaspsed time between pulses), and calculate the average windspeed since the last recording.
int AnemometerPin = D3;
float AnemometerScalekph = 1.492; // Windspeed if we got a pulse every second (i.e. 1Hz)
volatile unsigned int AnemoneterPeriodTotal = 0;
volatile unsigned int AnemoneterPeriodReadingCount = 0;
volatile unsigned int GustPeriod = UINT_MAX;
unsigned int lastAnemoneterEvent = 0;
void initializeAnemometer() {
pinMode(AnemometerPin, INPUT_PULLUP);
GustPeriod = UINT_MAX; // The shortest period (and therefore fastest gust) observed
attachInterrupt(AnemometerPin, handleAnemometerEvent, FALLING);
return;
void handleAnemometerEvent() {
// Activated by the magnet in the anemometer (2 ticks per rotation), attached to input D3
unsigned int timeAnemometerEvent = millis(); // grab current time
//If there's never been an event before (first time through), then just capture it
if(lastAnemoneterEvent != 0) {
// Calculate time since last event
unsigned int period = timeAnemometerEvent - lastAnemoneterEvent;
// ignore switch-bounce glitches less than 10mS after initial edge (which implies a max windspeed of 149kph)
if(period < 10) {
return;
if(period < GustPeriod) {
// If the period is the shortest (and therefore fastest windspeed) seen, capture it
GustPeriod = period;
AnemoneterPeriodTotal += period;
AnemoneterPeriodReadingCount++;
lastAnemoneterEvent = timeAnemometerEvent; // set up for next event
float getAndResetAnemometerkph(float * gustKPH)
if(AnemoneterPeriodReadingCount == 0)
*gustKPH = 0.0;
return 0;
// Nonintuitive math: We've collected the sum of the observed periods between pulses, and the number of observations.
// Now, we calculate the average period (sum / number of readings), take the inverse and muliple by 1000 to give frequency, and then mulitply by our scale to get kph.
// The math below is transformed to maximize accuracy by doing all muliplications BEFORE dividing.
float result = AnemometerScalekph * 1000.0 * float(AnemoneterPeriodReadingCount) / float(AnemoneterPeriodTotal);
*gustKPH = AnemometerScalekph * 1000.0 / float(GustPeriod);
return result;
// Wind Vane
void initializeWindVane() {
return;
// For the wind vane, we need to average the unit vector components (the sine and cosine of the angle)
int WindVanePin = A0;
float windVaneCosTotal = 0.0;
float windVaneSinTotal = 0.0;
unsigned int windVaneReadingCount = 0;
void captureWindVane() {
// Read the wind vane, and update the running average of the two components of the vector
unsigned int windVaneRaw = analogRead(WindVanePin);
float windVaneRadians = lookupRadiansFromRaw(windVaneRaw);
if(windVaneRadians > 0 && windVaneRadians < 6.14159)
windVaneCosTotal += cos(windVaneRadians);
windVaneSinTotal += sin(windVaneRadians);
windVaneReadingCount++;
return;
float getAndResetWindVaneDegrees()
if(windVaneReadingCount == 0) {
return 0;
float avgCos = windVaneCosTotal/float(windVaneReadingCount);
float avgSin = windVaneSinTotal/float(windVaneReadingCount);
float result = atan(avgSin/avgCos) * 180.0 / 3.14159;
// atan can only tell where the angle is within 180 degrees. Need to look at cos to tell which half of circle we're in
if(avgCos < 0) result += 180.0;
// atan will return negative angles in the NW quadrant -- push those into positive space.
if(result < 0) result += 360.0;
return result;
float lookupRadiansFromRaw(unsigned int analogRaw)
// The mechanism for reading the weathervane isn't arbitrary, but effectively, we just need to look up which of the 16 positions we're in.
if(analogRaw >= 2200 && analogRaw < 2400) return (3.14);//South
if(analogRaw >= 2100 && analogRaw < 2200) return (3.53);//SSW
if(analogRaw >= 3200 && analogRaw < 3299) return (3.93);//SW
if(analogRaw >= 3100 && analogRaw < 3200) return (4.32);//WSW
if(analogRaw >= 3890 && analogRaw < 3999) return (4.71);//West
if(analogRaw >= 3700 && analogRaw < 3780) return (5.11);//WNW
if(analogRaw >= 3780 && analogRaw < 3890) return (5.50);//NW
if(analogRaw >= 3400 && analogRaw < 3500) return (5.89);//NNW
if(analogRaw >= 3570 && analogRaw < 3700) return (0.00);//North
if(analogRaw >= 2600 && analogRaw < 2700) return (0.39);//NNE
if(analogRaw >= 2750 && analogRaw < 2850) return (0.79);//NE
if(analogRaw >= 1510 && analogRaw < 1580) return (1.18);//ENE
if(analogRaw >= 1580 && analogRaw < 1650) return (1.57);//East
if(analogRaw >= 1470 && analogRaw < 1510) return (1.96);//ESE
if(analogRaw >= 1900 && analogRaw < 2000) return (2.36);//SE
if(analogRaw >= 1700 && analogRaw < 1750) return (2.74);//SSE
if(analogRaw > 4000) return(-1); // Open circuit? Probably means the sensor is not connected
Particle.publish("error", String::format("Got %d from Windvane.",analogRaw), 60 , PRIVATE);
return -1;
