Electron Flashing Green - Will not connect until battery removed
Hi BDub,
Thanks for the information. I am in fact running multi-threaded. The reason for this is that I need to ensure that even when I’m turning on the modem and checking for a connection to particle cloud, the device isn’t blocked. After reading your message, I did a quick test to turn off multi-threading and it does indeed block when doing a connection which means the device can become unresponsive for a little while which is what I want to avoid.
Is there another way for me to approach the connecting every few hours but not blocking code? I reset 34 devices on Friday, delivered them to the field and confirmed they were all working, now after the weekend has passed, I’ve now got 4 devices that appear to be playing up and not checking in after the 6 hour interval. Some don’t check in at all, others come online in the console, but don’t publish then go offline.
I’m thinking that multi-threading could be causing my issues. My SIM cards have a 50MB monthly limit and I’m no where near that at the moment.
