Latest working…
// THIS SKETCH IS TO GATHER READINGS FROM SENSORS, IN THIS CASE THE BNO055, ADS1115, AND //
// MCP9808, AT A USER SET TIME INTERVAL (SET IN SECONDS) TO THEN BE PUBLISHED OUT ONCE THE //
// DESIRED NUMBER OF SAMPLES HAS BEEN OBTAINED. //
// DURING THIS, IF AN EVENT IS TRIGGERED - A STATE WHERE IF ANY ONE OF THE SENSOR'S VALUE //
// DIFFERS MORE THEN THE LAST FOUR VALUES AVERAGED TOGETHER + SENSOR ALERT SETPOINT //
// (sensor_alert_thrshld[X]), THE SENSOR SAMPLE TIME INTERVAL IS CHANGED UNTIL THE DEFINED //
// NUMBER OF PUBLISHED ALERT EVENTS HAS OCCURRED. //
// CONFIGURABLE SETTINGS ARE BELOW, UNDER *USER CONFIGURABLE PARAMETERS* //
// Following components are used: //
// -Pololu #2562, 5V Step-Up Voltage Regulator, https://www.pololu.com/product/2562/ //
// (100k onboard pullup removed, replaced with external 10k pulldown) //
// -ADS1115 16-Bit ADC - 4 Channel, https://www.adafruit.com/product/1085 //
// -MCP9808 High Accuracy I2C Temperature Sensor, https://www.adafruit.com/product/1782 //
// -BNO055 9-DOF Absolute Orientation IMU Fusion, https://www.adafruit.com/product/2472 //
#include "Particle.h"
#include "particle-BNO055.h"
#include <Wire.h>
#include <ADS1115.h>
#include "MCP9808.h"
#include <math.h>
SYSTEM_MODE(AUTOMATIC)
SYSTEM_THREAD(ENABLED)
ADS1115 ads;
MCP9808 mcp = MCP9808();
Adafruit_BNO055 bno = Adafruit_BNO055(55);
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ BEGIN USER CONFIGURABLE PARAMETERS \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// SAMPLE & PUBLISH SETTINGS //
int norm_smpl_intvl = 60; // SAMPLE INTERVAL, HOW MANY SECONDS TO WAIT BETWEEN EACH
const int rnds_to_publish = 5; // WAIT UNTIL x NUMBER OF SAMPLES ARE GATHERED TO BURST PUBLISH
int do_publish = 1; // PERFORM PARTICLE.PUBLISH EVENTS
// SENSOR REPORT CONFIG
const int no_of_sensors = 8; // THE NUMBER OF SENSOR READINGS TO COLLECT PER SAMPLE
// ▼ THE LENGTH OF EACH SENSOR'S VALUE
int sensorlen[no_of_sensors] = {4, 4, 4, 4, 3, 3, 3, 3};
// ALAERT SETTING //
int alert_smpl_intvl = 10; // ALERT SAMPLE INTERVAL, HOW MANY SECONDS TO WAIT BETWEEN EACH
const int alrt_publish_rnds = 2; // WHILE IN SENSOR ALERT - HOW MANY COMPLETE PUBLISH CYCLES TO LOOP THROUGH
// ▼ SET ARRAY FOR SENSOR ALERT
int sensor_alert_thrshld[no_of_sensors] = {999, 999, 999, 999, 2, 15, 15, 15};
// POWER SETTINGS //
int solar_opt = 0; // SOLAR OPTIMIZATION, 0 = SOLAR OPT OFF, 5 = 5V SOLAR PANEL, 6 = 6V SOLAR PANEL
int enable_wop = 0; // ENABLE WAKE-ON-PING
int sleep = 1; // SLEEP MODE ON = 1 / SLEEP MODE OFF = 0
int sleep_wait = 1; // TIME TO WAIT AFTER PUBLISH TO FALL ASLEEP
int secs_less_intrvl_sleep = 0; // ADDITIONAL SECONDS TO DELAY FROM SAMPLE INTERVAL FOR SLEEP TIME, 5 SECONDS ARE ALREADY SUBTRACTED
int app_watchdog = 360000; // APPLICATION WATCHDOG TIME TRIGGER IS MS - SLEEP TIME SHOULD NOT BE COUNTED
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END USER CONFIGURABLE PARAMETERS \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// DECLARE ITEMS USED AND SET INITIAL PARAMETERS
int alert_sample_qty = ((rnds_to_publish * alrt_publish_rnds) + 1); // HOW MANY SENSOR SAMPLES TO TAKE WHILE IN EVENT/ALERT MODE
float storage[(rnds_to_publish + 1)][no_of_sensors]; // DIMENSION THE STORAGE CONTAINER ARRAY
int current_smpl_intvl = norm_smpl_intvl; // SET CURRENT SAMPLE INTERVAL TO NORMAL SAMPLE INTERVAL AS ABOVE
char fullpublish[500]; // CONTAINS THE STRING TO BE PUBLISHED
char fullpub_temp1[16]; // TEMPORARY HOLDING STRING USED FOR FULLPUBLISH EVENT
int alrt_ckng_tmp = 0; // USED AS A TEMP CONTAINER IN SENSOR ALERT CHECKING
int w = 0; // THE NUMBER OF SAMPLES TO GATHER
int x = 0; // THE NUMBER OF SAMPLES COUNTER
int xa = 0; // THE NUMBER OF SAMPLES COUNTER in ALERT STATE
int y = 0; // THE SAMPLE PER COUNT GATHERED
int smpls_performed = 0; // COUNTER FOF ALL SAMPLES PERFORMED
int sensor_event_chk = 0; // SENSOR SAMPLE EVENT CHECK
int sensor_hist_depth = 0; // SENSOR SAMPLE EVENT CHECK DEPTH
int alert_cycl_mark = 0; // CYCLE MARK BASED ON 'smpls_performed' TO CONTINUE ALERT REPORTING
int t2 = 0; // EQUALS TIME(0) + norm_smpl_intvl, USED TO DETERMINE WHEN TO TAKE SAMPLE
int alrt_state_chng = 0; // CHANGE IN ALERT STATE FLAG
float sensor_value[no_of_sensors][7]; // DIMENSION THE SENSOR VALUE ARRAY
int vcell; // BATTERY INFO
int vsoc; // BATTERY INFO
int a = 0; // GP TIMER USE
int published_norm1_or_alert2 = 0; // TYPE OF PUBLISH LAST PERFORMED
int sla = 0; // USED IN CREATION OF PREAMBLE
int led1 = D7; // ONBOARD BLUE LED
int volt5 = D6; // 5V STEP-UP VOLTAGE REGULATOR ON/OFF CONTROL (SAME CONTROL AS LED)
int16_t adc0, adc1, adc2, adc3; // IMU
float adcx0, adcx1, adcx2, adcx3; // IMU
int sleeptime = 0; // SLEEP DURATION
// END OF DECLARATIONS AND INITIAL PARAMETERS
void i2cWake()
//WAKE UP i2c DEVICES
digitalWrite(volt5, HIGH); // TURN ON 5 VOLT REGULATOR
ads.setMode(MODE_CONTIN); // SET ADC SAMPLING MODE AS CONTINUOUS
mcp.setPowerMode(MCP9808_CONTINUOUS); // SET TEMP SENSOR MODE AS CONTINUOUS
Wire.beginTransmission(0x28); // TURN IMU ON
Wire.write(0x3E); // TURN IMU ON
Wire.write(0x00); // TURN IMU ON
Wire.endTransmission(); // TURN IMU ON
void i2cSleep()
//PUT i2c DEVICES TO SUSPEND
ads.setMode(MODE_SINGLE); // SET ADC SAMPLING MODE AS CONTINUOUS
mcp.setPowerMode(MCP9808_LOW_POWER); // SET TEMP SENSOR MODE AS CONTINUOUS
Wire.write(0x02); // TURN IMU ON
digitalWrite(volt5, LOW); // TURN OFF 5 VOLT REGULATOR
void preamble()
// PUT PREAMBLE ON DATA
fullpub_temp1[0] = 0;
fullpublish[0] = 0;
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%d%d", alrt_state_chng, no_of_sensors);
strncat(fullpublish, fullpub_temp1, sizeof(fullpublish) - strlen(fullpublish) - 1);
for (sla = 0; sla < no_of_sensors; sla++)
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%d", sensorlen[sla]);
void fullpublishout()
Particle.publish("a", fullpublish, 60, PRIVATE, NO_ACK); // PARTICLE.PUBLISH EVENT ! ! ! !
digitalWrite(led1, HIGH);
for (uint32_t ms = millis(); millis() - ms < 500; Particle.process())
digitalWrite(led1, LOW);
void setup()
Serial.begin(9600);
pinMode(led1, OUTPUT);
pinMode(volt5, OUTPUT);
// SOLAR SETTINGS //
if (solar_opt)
PMIC pmic; //INITIALIZE THE PMIC CLASS TO CALL THE POWER MANAGEMENT FUNCTIONS BELOW
pmic.setChargeCurrent(0, 0, 1, 0, 0, 0); //SET CHARGING CURRENT TO 1024MA (512 + 512 OFFSET)
if (solar_opt == 5)
pmic.setInputVoltageLimit(4840); //SET THE LOWEST INPUT VOLTAGE TO 4.84 VOLTS, FOR 5V SOLAR PANEL
if (solar_opt == 6)
pmic.setInputVoltageLimit(5080); //SET THE LOWEST INPUT VOLTAGE TO 5.08 VOLTS, FOR 6V SOLAR PANEL
Wire.begin(); // INITIALIZE I2C
for (uint32_t ms = millis(); millis() - ms < 500;)
bno.begin(); // INITIALIZE IMU
bno.setExtCrystalUse(true);
ads.getAddr_ADS1115(ADS1115_DEFAULT_ADDRESS); // (ADDR = GND)
ads.setGain(GAIN_TWOTHIRDS); // 2/3x gain +/- 6.144V 1 bit = 0.1875mV
ads.setMode(MODE_CONTIN); // ads.setMode(MODE_CONTIN) = Continuous conversion mode - ads.setMode(MODE_SINGLE); Power-down single-shot mode (default)
ads.setRate(RATE_128); // 128SPS (default) 8,16,32,64,128,250,475,860
ads.setOSMode(OSMODE_SINGLE); // Set to start a single-conversion
ads.begin();
mcp.setResolution(MCP9808_SLOWEST);
i2cWake();
ApplicationWatchdog wd(app_watchdog, System.reset);
void loop()
FuelGauge fuel;
if (a == 0 && fuel.getSoC() > 20)
if (enable_wop)
Cellular.command("AT+URING=1\r\n");
for (uint32_t ms = millis(); millis() - ms < 1000; Particle.process())
Particle.publish("a", "9 - DEVICE ONLINE!", 60, PRIVATE, NO_ACK); // LET SERVER KNOW ONLINE!
a = 2;
if (fuel.getSoC() < 20) //LOW BATTERY DEEP SLEEP
if (a != 0)
Particle.publish("a", "9 - DEVICE SHUTTING DOWN, BATTERY SoC < 20!", 60, PRIVATE, NO_ACK); // LET SERVER KNOW WE ARE GOING TO SLEEP
for (uint32_t ms = millis(); millis() - ms < 5000; Particle.process()) //EXTRA TIME BEFORE DEEP SLEEP
System.sleep(SLEEP_MODE_DEEP, 7200); // SLEEP 2 HOURS IF SoC < 20
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ START SENSOR VALUE GATHERING \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// SENSOR VALUES GO INTO THE sensor_value[X][0] ARRAY WHERE 'X' IS THE SENSOR NUMBER
// sensor_value[1][0] = SENSOR 1, SENSOR VALUE
// sensor_value[1][1-4] = SENSOR 1, HISTORICAL SENSOR VALUES
// sensor_value[1][5] = SENSOR 1, HISTORICAL SENSOR VALUE AVERAGE OF ALL FOUR
adc0 = ads.Measure_SingleEnded(0); //ADS1115 VOLTAGE READING 1
adcx0 = ((0.1875 * adc0) / 1000);
sensor_value[0][0] = adcx0;
adc1 = ads.Measure_SingleEnded(1); //ADS1115 VOLTAGE READING 2
adcx1 = ((0.1875 * adc1) / 1000);
sensor_value[1][0] = adcx1;
adc2 = ads.Measure_SingleEnded(2); //ADS1115 VOLTAGE READING 3
adcx2 = ((0.1875 * adc2) / 1000);
sensor_value[2][0] = adcx2;
adc3 = ads.Measure_SingleEnded(3); //ADS1115 VOLTAGE READING 4
adcx3 = ((0.1875 * adc3) / 1000);
sensor_value[3][0] = adcx3;
int tempget = fabs(10 * mcp.getTemperature()); //MCP9808 TEMP READING
sensor_value[4][0] = tempget;
sensors_event_t event; //BNO055 SAMPLE GATHERING
bno.getEvent(&event);
float orx = event.orientation.x; // BNO055 ORIENTATION X
// MAKE ORX RELATIVE TO 180'
int orxt1 = int(orx) - 180;
orxt1 = abs((orxt1 + 180) % 360 - 180);
int orxt2 = 180 - int(orx);
orxt2 = abs((orxt2 + 180) % 360 - 180);
if (orxt1 > orxt2)
sensor_value[5][0] = float(orxt2);
else
sensor_value[5][0] = float(orxt1);
float ory = event.orientation.y; // BNO055 ORIENTATION Y
ory = ory + 180;
sensor_value[6][0] = ory;
float orz = event.orientation.z; // BNO055 ORIENTATION Z
orz = orz + 180;
sensor_value[7][0] = orz;
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END SENSOR VALUE GATHERING \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/GATHER, EVENT CHECK, AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
//-- ALERT CHECK --
if (sensor_hist_depth == 4)
sensor_hist_depth = 1;
else
sensor_hist_depth++;
// CYCLE THROUGH 1 - 4 FOR HISTORY / AVERAGING
for (w = 0; w < no_of_sensors; w++)
sensor_value[w][5] = ((sensor_value[w][1] + sensor_value[w][2] + sensor_value[w][3] + sensor_value[w][4]) / 4);
sensor_value[w][sensor_hist_depth] = sensor_value[w][0];
if (smpls_performed > 4)
alrt_ckng_tmp = fabs(sensor_value[w][0] - sensor_value[w][5]);
sensor_value[w][6] = alrt_ckng_tmp;
if (alrt_ckng_tmp > sensor_alert_thrshld[w])
Serial.printf("OOS Sensor %d, ", w);
Serial.printlnf("Diff: %d, Threshold: %d.", alrt_ckng_tmp, sensor_alert_thrshld[w]);
if (alrt_state_chng != 2)
alrt_state_chng = 1; // SIGNIFIES FRESH CHANGE INTO ALERT STATE SO PUBLISHER WILL PUBLISH STORAGE AND THEN START ALERT REPORTING
alert_cycl_mark = smpls_performed + alert_sample_qty;
//-- END OF ALERT CHECK
//-- START SAMPLING TIME CHECK --
if (Time.now() >= t2)
storage[x][w] = sensor_value[w][0];
} //PLACE SENSOR VALUES IN STORAGE ARRAY
x++;
t2 = Time.now() + current_smpl_intvl;
if (alert_cycl_mark > smpls_performed)
Serial.println("!");
published_norm1_or_alert2 = 2;
else
Serial.println(".");
published_norm1_or_alert2 = 1;
smpls_performed++;
if (smpls_performed > alert_cycl_mark)
wd.checkin(); // SOFTWARE WATCHDOG CHECK-IN
if (alert_cycl_mark == (smpls_performed + 1))
alrt_state_chng = 3;
//-- END SAMPLING TIME CHECK --
//-- BEGIN ALERT STATE PUBLISH FLUSH --
if ((alrt_state_chng == 3) || (alrt_state_chng == 1))
preamble();
for (xa = 0; xa < x; xa++)
for (y = 0; y < no_of_sensors; y++)
if (y < 4)
{ //THIS IS TO LET THE FIRST FOUR READINGS HAVE TWO DECIMAL PLACES
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%0*.2f", sensorlen[y], storage[xa][y]);
else
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%0*.0f", sensorlen[y], storage[xa][y]);
strncat(fullpublish, fullpub_temp1, sizeof(fullpublish) - strlen(fullpublish) - 1); // better to check the boundaries
} // BUILT FULLPUBLISH STRING
x = 0;
xa = 0;
FuelGauge fuel; // GET BATTERY INFO
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "E%d%d%dT%ld", current_smpl_intvl, ((int)(fuel.getVCell() * 100)), ((int)(fuel.getSoC() * 100)), (t2 - Time.now())); // ADDING SAMPLE RATE, BATTERY INFO
Serial.println(fullpublish);
Serial.printf("ASP: The size of published string is %d bytes. \n", strlen(fullpublish));
if (do_publish)
fullpublishout();
if (alrt_state_chng == 1)
current_smpl_intvl = alert_smpl_intvl;
if (alrt_state_chng == 3)
//-- SEND OUT SYSTEM NOTE TO ALERT OOS AND FOR ON THE SPOT SENSOR VALUE REPORTING
fullpublish[0] = 0;
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "9 - OOS: ");
if (y < 4)
snprintf(fullpub_temp1, sizeof(fullpub_temp1), " '%0*.2f'%s%.0f>%d", sensorlen[y], sensor_value[y][0], ((sensor_value[y][6] > sensor_alert_thrshld[y]) ? "▲" : ":"), sensor_value[y][6], sensor_alert_thrshld[y]);
else
snprintf(fullpub_temp1, sizeof(fullpub_temp1), " '%0*.0f'%s%.0f>%d", sensorlen[y], sensor_value[y][0], ((sensor_value[y][6] > sensor_alert_thrshld[y]) ? "▲" : ":"), sensor_value[y][6], sensor_alert_thrshld[y]);
Serial.printf("The size of published string is %d bytes. \n", strlen(fullpublish));
if (do_publish)
fullpublishout();
alrt_state_chng = 2;
//-- END SEND OUT SYSTEM NOTE TO ALERT OOS
//-- END ALERT STATE PUBLISH FLUSH --
else
//-- START NORMAL CHECK AND PUBLISH --
if (x == rnds_to_publish)
preamble();
for (x = 0; x < rnds_to_publish; x++)
if (y < 4)
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%0*.2f", sensorlen[y], storage[x][y]);
else
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%0*.0f", sensorlen[y], storage[x][y]);
x = 0;
if (do_publish)
fullpublishout();
fullpublish[0] = 0; // CLEAR THE FULLPUBLISH STRING
//-- END SAMPLES TAKEN CHECK AND PUBLISH --
//-- BEDTIME CHECK --
if (sleep == 1)
if (published_norm1_or_alert2 == 1 && norm_smpl_intvl > 23 && t2 >= (Time.now() + sleep_wait))
sleeptime = (((norm_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait) - 5);
if (published_norm1_or_alert2 == 2 && alert_smpl_intvl > 23 && t2 >= (Time.now() + sleep_wait))
sleeptime = (((alert_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait) - 5);
if (enable_wop == 1 && sleeptime)
i2cSleep();
System.sleep({RI_UC, BTN}, {RISING, FALLING}, sleeptime, SLEEP_NETWORK_STANDBY);
i2cWake();
Cellular.command("AT+URING=0\r\n");
if (enable_wop == 0 && sleeptime)
i2cSleep();
System.sleep(BTN, FALLING, sleeptime, SLEEP_NETWORK_STANDBY);
i2cWake();
sleeptime = 0;
//-- END BEDTIME CHECK --
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END GATHER, EVENT CHECK, AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
for (uint32_t ms = millis(); millis() - ms < 700;)
