Thought up ways to cut back on data being published, came up and implemented this:
Follows is the firmware code. Webhook code and PHP receiver file are in the firmware code, at the bottom.
Updated 16 April, two minor calculation issues corrected, added padding for sensor values to ensure the length is as defined in preamble.
// THIS CODE SNIPPET IS TO GATHER READINGS FROM SENSORS AT A USER SET TIME INTERVAL (SET IN //
// SECONDS) TO THEN BE PUBLISHED OUT ONCE THE DESIRED NUMBER OF SAMPLES HAS BEEN OBTAINED. //
// DURING THIS, IF AN EVENT IS TRIGGERED - A STATE WHERE IF ANY ONE OF THE SENSOR'S VALUE //
// DIFFERS MORE THEN THE LAST FOUR VALUES AVERAGED TOGETHER + SENSOR ALERT SETPOINT //
// (sensor_alert_thrshld[X]), THE SENSOR SAMPLE TIME INTERVAL IS CHANGED UNTIL THE DEFINED //
// NUMBER OF PUBLISHED ALERT EVENTS HAS OCCURRED. THESE SETTINGS ARE BELOW, UNDER //
// *USER CONFIGURABLE PARAMETERS* //
// * * * NOTE THAT UNDER THE 'SENSOR VALUE EVENT CHECK' THE FOLLOWING TWO LINES WILL INSERT //
// A FALSE EVENT ON THE TWENTIETH SAMPLE TAKEN, ON SENSOR-3 AND AGAIN AT SAMPLE //
// TWENTY-THREE. DO NOT FORGET TO REMOVE THESE LINES * * * //
// if (smpls_performed == 21) sensor_value[3][5] += 100; // SIMULATE EVENT //
// if (smpls_performed == 23) sensor_value[3][5] += 100; // SIMULATE EVENT //
#include "Particle.h"
#include <math.h>
void setup();
void loop();
SYSTEM_MODE(AUTOMATIC)
SYSTEM_THREAD(ENABLED)
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ BEGIN USER CONFIGURABLE PARAMETERS \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// SAMPLE & PUBLISH SETTINGS //
int norm_smpl_intvl = 88; // SAMPLE INTERVAL, HOW MANY SECONDS TO WAIT BETWEEN EACH
const int rnds_to_publish = 15; // WAIT UNTIL x NUMBER OF SAMPLES ARE GATHERED TO BURST PUBLISH
int do_publish = 1; // PERFORM PARTICLE.PUBLISH EVENTS
// SENSOR REPORT CONFIG
const int no_of_sensors = 6; // THE NUMBER OF SENSOR READINGS TO COLLECT PER SAMPLE
int sensorlen[no_of_sensors] = {3, 3, 3, 3, 3, 3}; // THE LENGTH OF EACH SENSOR'S VALUE
// ALAERT SETTING //
int alert_smpl_intvl = 30; // ALERT SAMPLE INTERVAL, HOW MANY SECONDS TO WAIT BETWEEN EACH
const int alrt_publish_rnds = 2; // WHILE IN SENSOR ALERT - HOW MANY COMPLETE PUBLISH CYCLES TO LOOP THROUGH
int sensor_alert_thrshld[no_of_sensors] = {10, 11, 12, 13, 14, 15}; // SET ARRAY FOR SENSOR ALERT
// SLEEP SETTINGS //
int enable_wop = 1; // ENABLE WAKE-ON-PING
int sleep = 1; // SLEEP MODE ON = 1 / SLEEP MODE OFF = 0
int sleep_wait = 1; // TIME TO WAIT AFTER PUBLISH TO FALL ASLEEP
int secs_less_intrvl_sleep = 3; // SECONDS TO DELAY FROM SAMPLE INTERVAL FOR SLEEP TIME
int app_watchdog = 90000; // APPLICATION WATCHDOG TIME TRIGGER IS MS - SLEEP TIME SHOULD NOT BE COUNTED,
// BUT THE ABOVE THREE VARIABLES SHOULD BE BUT NOT LESS THEN 30000
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END USER CONFIGURABLE PARAMETERS \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// DECLARE ITEMS USED AND SET INITIAL PARAMETERS
int alert_sample_qty = ((rnds_to_publish * alrt_publish_rnds) + 1); // HOW MANY SENSOR SAMPLES TO TAKE WHILE IN EVENT/ALERT MODE
float storage[(rnds_to_publish + 1)][no_of_sensors]; // DIMENSION THE STORAGE CONTAINER ARRAY
int current_smpl_intvl = norm_smpl_intvl; // SET CURRENT SAMPLE INTERVAL TO NORMAL SAMPLE INTERVAL AS ABOVE
char fullpublish[500]; // CONTAINS THE STRING TO BE PUBLISHED
char fullpub_temp1[14]; // TEMPORY HOLDING STRING USED FOR FULLPUBLISH EVENT
char fullpub_temp2[4]; // TEMPORY HOLDING STRING USED FOR FULLPUBLISH EVENT
int alrt_ckng_tmp = 0; // USED AS A TEMP CONTAINER IN SENSOR ALERT CHECKING
int w = 0; // THE NUMBER OF SAMPLES TO GATHER
int x = 0; // THE NUMBER OF SAMPLES COUNTER
int xa = 0; // THE NUMBER OF SAMPLES COUNTER in ALERT STATE
int y = 0; // THE SAMPLE PER COUNT GATHERED
int pubs_performs = 0; // COUNTER FOF ALL PUBLISHES PERFORMED
int smpls_performed = 0; // COUNTER FOF ALL SAMPLES PERFORMED
int sensor_event_chk = 0; // SENSOR SAMPLE EVENT CHECK
int sensor_hist_depth = 0; // SENSOR SAMPLE EVENT CHECK DEPTH
int alert_cycl_mark = 0; // CYCLE MARK BASED ON 'smpls_performed' TO CONTINUE ALERT REPORTING
int t2 = 0; // EQUALS TIME(0) + norm_smpl_intvl, USED TO DETERMINE WHEN TO TAKE SAMPLE
int alrt_state_chng = 0; // CHANGE IN ALERT STATE FLAG
float sensor_value[no_of_sensors][6]; // DIMENSION THE SENSOR VALUE ARRAY
int vcell; // BATTERY INFO
int vsoc; // BATTERY INFO
int a = 0; // GP TIMER USE
int published_norm1_or_alert2 = 0; // TYPE OF PUBLISH LAST PERFORMED
int sla = 0; // USED IN CREATION OF PREAMBLE
int led1 = D7; // ONBOARD BLUE LED
// END OF DECLARATIONS AND INITIAL PARAMETERS
pinMode(led1, OUTPUT);
// SOLAR SETTINGS //
//PMIC pmic; //INITIALIZE THE PMIC CLASS TO CALL THE POWER MANAGEMENT FUNCTIONS BELOW
//pmic.setChargeCurrent(0,0,1,0,0,0); //SET CHARGING CURRENT TO 1024MA (512 + 512 OFFSET)
//pmic.setInputVoltageLimit(4840); //SET THE LOWEST INPUT VOLTAGE TO 4.84 VOLTS, FOR 5V SOLAR PANEL
//pmic.setInputVoltageLimit(5080); //SET THE LOWEST INPUT VOLTAGE TO 5.08 VOLTS, FOR 6V SOLAR PANEL
ApplicationWatchdog wd(app_watchdog, System.reset);
FuelGauge fuel;
if (a == 0 && fuel.getSoC() > 20)
Cellular.command("AT+URING=1\r\n");
for (uint32_t ms = millis(); millis() - ms < 2000; Particle.process())
a = 1;
if (fuel.getSoC() < 20) //LOW BATTERY DEEP SLEEP
if (a != 0)
Particle.publish("a", "9 - DEVICE SHUTTING DOWN FOR 8 HOURS, BATTERY SoC < 20!", 60, PRIVATE, NO_ACK); // LET SERVER KNOW WE ARE GOING TO SLEEP
delay(1000);
System.sleep(SLEEP_MODE_DEEP, 14400); // SLEEP 8 HOURS IF SoC < 20
if (a == 1)
Particle.publish("a", "9 - DEVICE ONLINE!", 60, PRIVATE, NO_ACK); // LET SERVER KNOW ONLINE!
a = 2;
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ START SENSOR VALUE GATHERING \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// SENSOR VALUES GO INTO THE sensor_value[X][0] ARRAY WHERE 'X' IS THE SENSOR NUMBER
// sensor_value[1][0] = SENSOR 1, SENSOR VALUE
// sensor_value[1][1-4] = SENSOR 1, HISTORICAL SENSOR VALUES
// sensor_value[1][5] = SENSOR 1, HISTORICAL SENSOR VALUE AVERAGE OF ALL FOUR
sensor_value[0][0] = random(441, 450); // PLACES RANDOM VALUES FOR TESTING
sensor_value[1][0] = random(461, 470); // PLACES RANDOM VALUES FOR TESTING
sensor_value[2][0] = random(471, 480); // PLACES RANDOM VALUES FOR TESTING
sensor_value[3][0] = random(481, 490); // PLACES RANDOM VALUES FOR TESTING
sensor_value[4][0] = random(491, 500); // PLACES RANDOM VALUES FOR TESTING
sensor_value[5][0] = random(501, 510); // PLACES RANDOM VALUES FOR TESTING
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END SENSOR VALUE GATHERING \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/GATHER, EVENT CHECK, AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
//-- BEGIN SENSOR EVENT CHECK --
if (smpls_performed > sensor_event_chk)
sensor_event_chk = smpls_performed;
if (sensor_hist_depth == 4)
sensor_hist_depth = 1;
else
sensor_hist_depth++;
} // CYCLE THROUGH 1 - 4 FOR HISTORY / AVERAGING
for (w = 0; w < no_of_sensors; w++)
sensor_value[w][5] = ((sensor_value[w][1] + sensor_value[w][2] + sensor_value[w][3] + sensor_value[w][4]) / 4);
sensor_value[w][sensor_hist_depth] = sensor_value[w][0];
sensor_value[3][5] += 100; // SIMULATE EVENT * * * *
if (smpls_performed > 4)
alrt_ckng_tmp = fabs(sensor_value[w][0] - sensor_value[w][5]);
if (alrt_ckng_tmp > sensor_alert_thrshld[w])
Serial.printf("OOS Sensor %d, ", w);
Serial.printlnf("Diff: %d, Threshold: %d.", alrt_ckng_tmp, sensor_alert_thrshld[w]);
// DO SOMETHING HERE LIKE ALTER REPORTING TIMES OR SEND ALERT
if (alrt_state_chng != 2)
alrt_state_chng = 1; // SIGNIFIES FRESH CHANGE INTO ALERT STATE SO PUBLISHER WILL PUBLISH STORAGE AND THEN START ALERT REPORTING
current_smpl_intvl = alert_smpl_intvl;
alert_cycl_mark = smpls_performed + alert_sample_qty;
if (smpls_performed > alert_cycl_mark)
// CHECK IF WE ARE IN AN ALERT REPORT CONDITION AND SEE IF WE SHOULD COME OUT OF IT
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END SENSOR EVENT CHECK \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ START SAMPLING TIME CHECK \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
if (Time.now() > t2)
storage[x][w] = sensor_value[w][0];
} //PLACE SENSOR VALUES IN STORAGE ARRAY
x++;
t2 = Time.now() + current_smpl_intvl;
if (alert_cycl_mark > smpls_performed)
Serial.println("!");
published_norm1_or_alert2 = 2;
else
Serial.println(".");
published_norm1_or_alert2 = 1;
smpls_performed++;
wd.checkin(); // SOFTWARE WATCHDOG CHECK-IN
if (alert_cycl_mark == (smpls_performed + 1))
alrt_state_chng = 3;
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END SAMPLING TIME CHECK \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ START BEDTIME CHECK \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
if (sleep == 1 && published_norm1_or_alert2 == 1 && norm_smpl_intvl > 18 && t2 >= (Time.now() + sleep_wait))
if (enable_wop)
System.sleep({RI_UC, BTN}, {RISING, FALLING}, (((norm_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait) - 2), SLEEP_NETWORK_STANDBY);
Cellular.command("AT+URING=0\r\n");
else
System.sleep(BTN, FALLING, ((norm_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait), SLEEP_NETWORK_STANDBY);
if (sleep == 1 && published_norm1_or_alert2 == 2 && alert_smpl_intvl > 18 && t2 >= (Time.now() + sleep_wait))
if (enable_wop)
System.sleep({RI_UC, BTN}, {RISING, FALLING}, (((alert_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait) - 2), SLEEP_NETWORK_STANDBY);
else
System.sleep(BTN, FALLING, ((alert_smpl_intvl - secs_less_intrvl_sleep) - sleep_wait), SLEEP_NETWORK_STANDBY);
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END BEDTIME CHECK \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ BEGIN ALERT STATE PUBLISH FLUSH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
if ((alrt_state_chng == 3) || (alrt_state_chng == 1 && alert_cycl_mark > smpls_performed))
fullpub_temp1[0] = 0;
fullpublish[0] = 0; // THIS IS NEW STUFF TO PUT PREAMBLE ON DATA
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%d%d", alrt_state_chng, no_of_sensors);
strncat(fullpublish, fullpub_temp1, sizeof(fullpublish) - strlen(fullpublish) - 1);
for (sla = 0; sla < no_of_sensors; sla++)
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%d", sensorlen[sla]);
} // END OF NEW STUFF TO PUT PREAMBLE ON DATA
for (xa = 0; xa < x; xa++)
for (y = 0; y < no_of_sensors; y++)
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "%0*.0f", sensorlen[y], storage[x][y]);
strncat(fullpublish, fullpub_temp1, sizeof(fullpublish) - strlen(fullpublish) - 1); // better to check the boundaries
} // BUILT FULLPUBLISH STRING
x = 0;
xa = 0;
if (alrt_state_chng == 1)
alrt_state_chng = 2;
if (strlen(fullpublish) != 0)
FuelGauge fuel; // GET BATTERY INFO
snprintf(fullpub_temp1, sizeof(fullpub_temp1), "E%d%d%d", current_smpl_intvl, ((int)(fuel.getVCell() * 100)), ((int)(fuel.getSoC() * 100))); // ADDING SAMPLE RATE, BATTERY INFO
Serial.println(fullpublish);
Serial.printf("ASP: The size of published string is %d bytes. \n", strlen(fullpublish));
if (do_publish)
Particle.publish("a", fullpublish, 60, PRIVATE, NO_ACK); // PARTICLE.PUBLISH EVENT ! ! ! !
digitalWrite(led1, HIGH);
delay(200);
digitalWrite(led1, LOW);
fullpublish[0] = 0; // CLEAR THE FULLPUBLISH STRING
pubs_performs++;
if (alrt_state_chng == 3)
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END ALERT STATE PUBLISH FLUSH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ START SAMPLES TAKEN CHECK AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
if (x == rnds_to_publish)
for (x = 0; x < rnds_to_publish; x++)
strncat(fullpublish, fullpub_temp1, sizeof(fullpublish) - strlen(fullpublish) - 1); // check the boundaries of fullpublish
x = 0;
Serial.printf("The size of published string is %d bytes. \n", strlen(fullpublish));
if (do_publish)
delay(200);
pubs_performs++;
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END SAMPLES TAKEN CHECK AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END GATHER, EVENT CHECK, AND PUBLISH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
///\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/ END OF SKETCH \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/
// WEBHOOK, DO SEARCH AND REPLACE AS "//--" TO "" TO MAKE USABLE, THEN PASTE INTO CUSTOM TEMPLATE WEBHOOK AREA
//--"event": "a",
//--"url": "http://BLAHBLAHBLAH/RECEIVER.php",
//--"requestType": "GET",
//--"noDefaults": false,
//--"rejectUnauthorized": false,
//--"query": {
//-- "id": "{{SPARK_EVENT_VALUE}}",
//-- "location": "{{SPARK_CORE_ID}}"
// END OF CUSTOM WEBHOOK
//-- RECEIVER.php FILE, DO SEARCH AND REPLACE AS "//--" TO "" TO MAKE USABLE
//-- <?php
//-- if (!isset($_GET["data"]))
//-- echo "404";
//-- die();
//-- $incoming = htmlspecialchars($_GET["data"]); // GET THE PUBLISHED INFORMATION SENT
//-- $coreid = htmlspecialchars($_GET["coreid"]);
//-- $published = htmlspecialchars($_GET["published_at"]); // GET THE TIME SENT
//-- $published = str_replace("-", "/", $published);
//-- $date = substr($published, 0, 10); // CLEAN UP THE DATE / TIME RVCD SO WE CAN USE IT BETTER IN CSV FILE LATER
//-- $time = substr($published, 11, 8);
//-- $datetime = $date . " " . $time;
//-- $datetime2 = $datetime;
//-- if ((substr($incoming, 0, 1)) == "9")
//-- echo "* * * " . $incoming . " * * *";
//-- $fp = fopen('ark/system.csv', 'a');
//-- fwrite($fp, $datetime . "," . substr($incoming,4,99) . "\n");
//-- fclose($fp);
//-- die();
//-- echo "Publish string: \n" . $incoming . "\n\n";
//-- $inlength = strlen($incoming);
//-- $involts = substr($incoming, -4); // GET THE VOLTAGE
//-- $insoc = substr($incoming, -7, 3); // GET THE SOC
//-- $intrvl = substr($incoming, strpos($incoming, 'E') + 1, ($length - 7));
//-- $striplen = strlen($intrvl) + 8; // CALCULATE WHERE TO CUT THE EXTRA DATA FROM SENSOR DATA
//-- $process = substr($incoming, 0, ($length - $striplen)); // CUT OFF EXTRA DATA - JUST LEAVE SENSOR DATA
//-- $isalert = substr($incoming, 0, 1);
//-- $number_sensors = substr($incoming, 1, 1);
//-- echo "Length: " . $inlength . ", Battery SoC: " . ($involts / 100) . ", Battery Volts: " . ($insoc / 100) . "\n";
//-- echo "Alert Flag: " . $isalert . ", Number of sensors: " . $number_sensors . ".\n";
//-- for ($i = 0; $i < $number_sensors; $i++)
//-- echo "Sensor " . ($i + 1) . ": " . substr($incoming, ($i + 2) , 1) . " chars ";
//-- $preamble = $number_sensors + 2;
//-- $rawdata = substr($process, $preamble);
//-- for ($a = 0; $a < $number_sensors; $a++)
//-- $sensetln = $sensetln + (substr($incoming, ($a + 2) , 1));
//-- $setspublished = strlen($rawdata) / $sensetln;
//-- $roundmin = ($intrvl * $setspublished) / 60;
//-- $roundtime = number_format((float)$roundmin, 1, '.', '');
//-- echo "Sample Interval: " . $intrvl . " - Sample Rounds: " . $setspublished . ", with a publish interval time of " . $roundtime. " minutes.\n";
//-- $delin = $setspublished;
//-- $b = 0;
//-- $build2 = "";
//-- for ($x = 0; $x < $setspublished; $x++)
//-- $build = substr($rawdata, $b, (substr($incoming, ($a + 2) , 1)));
//-- $b = $b + (substr($incoming, ($a + 2) , 1));
//-- $build2.= $build . ",";
//-- $build3 = substr($build2, 0, (strlen($build2) - 1));
//-- $inArray[$x] = $build3;
//-- $build1 = ""; $build2 = ""; $build3 = "";
//-- $sectodel = $intrvl * $setspublished;
//-- $timestamp = date('Y/m/d H:i:s', strtotime('-' . $sectodel . ' seconds', strtotime($datetime2)));
//-- $datetime = $timestamp;
//-- for ($i = 0; $i < $setspublished; $i++)
//-- $sectoadd = ($intrvl * ($i + 1));
//-- $datetimeN = date('Y/m/d H:i:s', strtotime('+' . $sectoadd . ' seconds', strtotime($timestamp)));
//-- $inArray[$i] = $datetimeN . "," . $inArray[$i] . "\n";
//-- $fp = fopen('ark/lf.csv', 'a'); // WRITE SENSOR DATA TO CSV FILE NAMED lf.csv LOCATED IN THE ark FOLDER
//-- for ($i = 0; $i < ($delin); $i++)
//-- fwrite($fp, $inArray[$i]);
//-- fclose($fp);
//-- $fp = fopen('ark/p1f.csv', 'a'); // WRITE SOC DATA TO CSV FILE NAMED p1f.csv
//-- fwrite($fp, $datetime2 . "," . ($insoc / 100) . "\n");
//-- fclose($fp);
//-- $fp = fopen('ark/p2f.csv', 'a'); // WRITE VOLTS DATA TO CSV FILE NAMED p2f.csv
//-- fwrite($fp, $datetime2 . "," . ($involts / 100) . "\n");
//-- fclose($fp);
//-- echo "Received particle publish marked with time: " . $datetime2 . ", calculated time: " . $datetimeN . "!"; // LET THE WEBHOOK KNOW WE RCVD AND AT WHAT TIME
//-- END OF RECEIVER.php FILE
Suggestions, corrections, or critiques are warmly welcomed!
/r,
Kolbi
