EEPROM Data corrupt after reboot (no power loss)
I’m having an unusual issue recalling data from EEPROM after rebooting the device. I am "put"ing data , and even verifying it with a “get” immediately after. It only (seem to) happen in this specific memory address location of 72.
long SomeVar = 55662;
long SomeVar2;
EEPROM.put(72, someVar);
EEPROM.get(72, someVar2);
Serial.println("Before: " + String(SomeVar ) + ", After: " + String(someVar2));
The variable is correctly written to the EEPROM… and while I am performing
other EEPROM.PUT’s in my code after this in other memory locations, evertime I am, I have debugged it to Serial output and verified the stored value is still correct (“55662” in this example).
However, if I call System.reset(); to reboot the device, press the Reset button, or if I send a firmware update to the device, or if I power cycle it, in all scenarios, when I call EEPROM.get(72, someVar2); again, the value always comes back with a whacky value, such as maybe something like 11223. Its always comes back something different, only after a reboot.
Things I know:
  1. It always does it (System.reset(), firmware update, reset, or a power cycle)
  2. I’m using Device OS 1.0.1
  3. I don’t seem to have any issues with the fetching of data from the EEROM in other memory address locations before/after this location of 72. For example I am storing long data type variables in address 68 and 76 and they seem to be recalled without any issues.
I found in a old forum post that I can data dump the eeprom to a file using the following command line:
dfu-util -d 2b04:d006 -a 0 -s 0x800C000:0x18000 -D eeprom.bin
However this forum post was from 2015, and when I try it now, I get an error:
Downloading to address = 0x0800c000, size = 0
Last page at 0x0800bfff is not writeable
I presume the error is because the EEPROM flash address location has changed since DeviceOS 1.0.1? Does anyone know a updated command line to data dump the EEPROM?
In any case… I’m not sure what else to try here to debug this issue.
Any ideas?
Does this also happen with a test code that only uses this memory location and does nothing else?
A link to the respective forum post would be good.
That is my next step in debugging this issue, is to get rid of all of the other EEPROM.Put()'s and start working backwards. I may go as far as starting a new project that does nothing but read/write to the EEPROM to try to reproduce the issue in a separate project.
Here is the link to the article that had info on how to dump the EEPROM to a file: https://community.particle.io/t/eeprom-values-wiped/16568/4
I think I figured out the issue. Their was a variable I was putting in memory address location 68 that used to be 4 bytes (long), but I have since changed the variable two a struct that contains two long values, so the new length is 8 bytes.
Also, in my debugging, I was “verifying” the stored value in the memory address location 72 in a loop that was storing values in the address location 68 but was out of order.
I was able to figure this issue out by debugging to the size of each of the variables I am storing to the EERPROM by outputting to Serial output using the sizeof() function. That’s when I discovered the size of the variable in in address location 68 was in fact 8 bytes long.
I’m still curious if someone tell me the proper dfu-util command for DeviceOS 1.0.1 to output the EEPROM to a binary file
Try -U instead of -D
For me the naming of the switches also seems twisted but this is how dfu-util -? describes the switches
dfu-util 0.8
 -U --upload <file>            Read firmware from device into <file>
 -D --download <file>          Write firmware from <file> into device
I’d think you want to “download” from the devices and upload to the device, but dfu-util (at least 0.8) seems to see this differently :wink:
Thank you. I will give that a try.
