DS18B20 with Photon [SOLVED]
@gruberlu, Thanks for the update, I’ve been testing OneWire on the Electron exclusively for the last month. Well it is running 24/7 on a Photon in my weather station without issue. Glad your up and running!
All - Make sure you are adding the latest version (you can pick the version you want). When upgrading a lib you have to remove, then re-add it to your project to actually change the code that is used.
