Downloading Lots Of Data
I recently needed to download a large amount of data from the Spark Core using Variables. Due to memory limitations, I was limited to what I could do, and was constantly being pushed towards the limits of the Spark Core, both in terms of Flash and RAM. This is how I solved the problem.
I was initially generating CSV strings using the Strings class. This caused me to use a lot of storage space, and also RAM. sprintf actually made matters worse. Then I went old school, and found an itoa library on the web, and implemented that. It helped.
Please bear in mind I then stopped using the following code… as will be explained later.
#define ALPHANUMS "zyxwvutsrqponmlkjihgfedcba9876543210123456789abcdefghijklmnopqrstuvwxyz"
int itoa(int number, char* out, int base) {
   int t, count;
     char *p, *q;
     char c;
     p = q = out;
     if (base < 2 || base > 36) base = 10;
     do {
         t = number;
         number /= base;
         if (out) *p = ALPHANUMS[t+35 - number*base];
         p++;
     } while (number);
     if (t < 0) {
          if (out) *p = '-';
          p++;
     count = p-out;
     if (out) {
         *p-- = '\0';
         while(q < p) {
             c = *p;
             *p-- = *q;
             *q++ = c;
     return count;
I would then build the string up ‘old school’ in the following manner:
itoa (HARDWARE_PRODUCT,temp,10);
strcat (v_version,temp);
It worked, but was not ideal. One of my data storage structures on the Spark Core looked like the following:
#define CIRCUIT_COUNT 8
struct BillingPosStruct {
    unsigned int start;
    unsigned int last;
    struct {
        unsigned int PP_POS_CNT;
        unsigned int PQ_POS_CNT;
        unsigned int PS_CNT;
    } count[CIRCUIT_COUNT + 1];
struct BillingPosStruct BillingPos;
This took up 116 bytes of RAM in itself, and would require significantly more as a comma delimited string.
I ended up encoding it as a BASE64 string, meaning I could send it as a 156 character string, which is still long, but not too bad. The BASE64 library I used appears below.
// base 64
 static char encoding_table[] = {'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H',
                                'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P',
                                'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X',
                                'Y', 'Z', 'a', 'b', 'c', 'd', 'e', 'f',
                                'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n',
                                'o', 'p', 'q', 'r', 's', 't', 'u', 'v',
                                'w', 'x', 'y', 'z', '0', '1', '2', '3',
                                '4', '5', '6', '7', '8', '9', '+', '/'};
static int mod_table[] = {0, 2, 1};
void base64_encode(char *data,
                    size_t input_length,
                    char *encoded_data) {
    // From http://stackoverflow.com/questions/342409/how-do-i-base64-encode-decode-in-c
    int  output_length = ((input_length - 1) / 3) * 4 + 4;
    encoded_data[output_length] = 0;
    for (unsigned int i = 0, j = 0; i < input_length;) {
        unsigned int octet_a = i < input_length ? (unsigned char)data[i++] : 0;
        unsigned int octet_b = i < input_length ? (unsigned char)data[i++] : 0;
        unsigned int octet_c = i < input_length ? (unsigned char)data[i++] : 0;
        unsigned int triple = (octet_a << 0x10) + (octet_b << 0x08) + octet_c;
        encoded_data[j++] = encoding_table[(triple >> 3 * 6) & 0x3F];
        encoded_data[j++] = encoding_table[(triple >> 2 * 6) & 0x3F];
        encoded_data[j++] = encoding_table[(triple >> 1 * 6) & 0x3F];
        encoded_data[j++] = encoding_table[(triple >> 0 * 6) & 0x3F];
    for (int i = 0; i < mod_table[input_length % 3]; i++)
        encoded_data[output_length - 1 - i] = '=';
To use this I used the following code
char v_energy_pos[165];
base64_encode ((char *)&BillingPos, sizeof (BillingPos), v_energy_pos);
This was sent as a Spark variable
Spark.variable ("energy_pos", &v_energy_pos, STRING);
To read this on the other side, I will give you a snippet in Python.
ret = myCore.readVariable('energy_pos')
dec = base64.b64decode(ret)
un = unpack ("IIIIIIIIIIIIIIIIIIIIIIIIIIIII", dec)
At least in Python, you can find information on decoding the structures at the following URL https://docs.python.org/2/library/struct.html
In my case, The upper case I represents 4 byte unsigned integers. The unpacked data is a list of the values of the integers which can then be used as normal.
I am not saying that any of this is an ideal solution to getting a lot of data around, but when you have a lot of data, it seems to work for me
Darryl
The itoa() function is around but not easy to get to–it is in the String module.
You can access it with this:
extern char* itoa(int a, char* buffer, unsigned char radix);
