In the docs, it says “Publish a private event with the given name, data, and TTL. In order to publish a private event, you must pass all four parameters.” However, right after that, there are several examples that seem to suggest otherwise.
Is this just a bug in the documentation? If so, does this suffice to report it?
This seems to be the docs lagging the actual firmware.
Currently the TTL parameter doesn’t do anything so it can be omitted.
But since the upcoming 0.7.0 release will change some bits and 0.8.0 will require an explicit statement whether the publish should be PUBLIC or PRIVATE, I guess the docs will be updated soon.
OK, thanks, ScruffR! I’ll just be patient …
