Digital Switch strange results
I am not always printing the message “switch open interrupt!” when I open a closed switch.
I use D6 and set it high and connect to D7 via a digital closed switch. With this setup the D7 blue led is on, but getting strange results when opening switch multiple times. Is this a correct setup to monitor a closed switch and generate an interrupt when it goes open?
int switch = D7;
int sethigh3v = D6;
    pinMode(sethigh3v, OUTPUT);
    digitalWrite(sethigh3v, HIGH);
    pinMode(switch, INPUT_PULLDOWN);
    attachInterrupt(switch, isrEvent, FALLING);
	//check digital switch
	checkEvents();
void isrEvent() {
    if (digitalRead(button)==HIGH && systemHasNoticed == false) {
      systemHasNoticed = true;
void checkEvents() {
 if(digitalRead(button)==HIGH && systemHasNoticed == true) {
     Serial.println("switch open interrupt!");
     systemHasNoticed = false;
When triggering on a falling edge you’d usually use INPUT_PULLUP and close the switch to GND.
Also we can’t see your declaration of systemHasNoticed - this boolean should be marked volatile.
Yes declaration of systemHasNoticed is marked volatile, but I changed the
attachInterrupt(switch, isrEvent, FALLING); to attachInterrupt(switch, isrEvent, RISING);
and using switch as normally open rather than normally closed.
This seems to have cleared up the issue.
thanks for your help.
Thanks for the assist!
