Good morning.
I have connected some relays, LEDs and buttons to my Xenons and Argons. I have noticed that the Digital IO change state during firmware uploads and when Argon/Xenon boot up. The Analog IO does not. My problem is that some of my Digital IO is connected to a relay that triggers an alarm, so every time I program or reset them the alarm is triggered. Where in the particle firmware is the pins declared and set?
The analog pins I reconfigure to digital and they do not do this. In the code below the PCH and NCH pins does not alter state during boot up or programming, but the relays and RGB pins triggers.
Thank you as always.
const int RELAY1 = D4;//relay
const int RELAY2 = D5;//relay
const int PCH1= A1;//PNP output drive
const int NCH1 = A0;//NPN outout drive
const int LOAD = D3;//button
const int CLEAR = D2;//button
const int led_green = D8;//rgb
const int led_red = D6;//rgb
const int led_blue= D7;//rgb
int buttonLOAD;//hold button load value
int buttonCLEAR;//hold button clear value
SYSTEM_MODE(AUTOMATIC);
Particle.keepAlive(20);
Serial.begin(115200);
pinMode(RELAY1, OUTPUT);//output for relay
pinMode(RELAY2, OUTPUT);//output for relay
pinMode(led_red, OUTPUT);//output for rgb
pinMode(led_green, OUTPUT);//output frgb
pinMode(led_blue, OUTPUT);//output rgb
pinMode(PCH1, OUTPUT);//output for p channel
pinMode(NCH1, OUTPUT);//output for n channel
pinMode(LOAD, INPUT);//button
pinMode(CLEAR, INPUT);//button
digitalWrite (led_blue, HIGH);//led off
digitalWrite (led_green, HIGH);//led off
digitalWrite (led_red, HIGH);//led off
digitalWrite (RELAY1, LOW);//relay off
digitalWrite (RELAY2, LOW);//relay off
