All a sudden none of my API requests to my product are working. I tried creating a new set of Oauth credentials but get the same errors. Did something change? In particular I’m using attempting to create customers. Used this same API a couple days ago with no changes and it worked then…
Now same API requets is returning: “email was empty” … didn’t change anything here…
Hi incorvia,
We are currently investigating this issue on our end. As I have more information, I’ll be sure to update you here.
@incorvia would you be able to check API request statuses? It should be up and running again as intended.
It does look like it works now. Thank you.
