That is likely to happen because the DHT-11 is not a great sensor to use on Gen 3 Particle devices, even though it’s included in the kit. Any number of I2C sensors such as the DS75 and SHT-31D work far better, especially with the Tracker One.
It’s very common to get nan results with the Grove_Temperature_And_Humidity_Sensor library, because the sensor fails to read properly. Bits slip due to interrupt latency because the BLE radio on the nRF52840 runs at a high priority, and runs even if interrupts are disabled via noInterrupts().
0000099452 [app] INFO: temp=nan hum=19.000000
0000101452 [app] INFO: temp=nan hum=22.000000
0000103452 [app] INFO: temp=nan hum=22.000000
0000105452 [app] INFO: temp=nan hum=22.000000
0000107452 [app] INFO: temp=nan hum=22.000000
0000109452 [app] INFO: temp=nan hum=22.000000
0000111452 [app] INFO: temp=nan hum=22.000000
0000113452 [app] INFO: temp=nan hum=22.000000
0000115452 [app] INFO: temp=nan hum=22.000000
0000117452 [app] INFO: temp=nan hum=22.000000
0000119452 [app] INFO: temp=22.000000 hum=22.000000
0000455453 [app] INFO: temp=nan hum=23.000000
0000457453 [app] INFO: temp=22.000000 hum=22.000000
0000459453 [app] INFO: temp=22.000000 hum=23.000000
0000461453 [app] INFO: temp=22.000000 hum=22.000000
0000463453 [app] INFO: temp=nan hum=23.000000
0000465453 [app] INFO: temp=22.000000 hum=22.000000
0000467456 [app] INFO: temp=nan hum=0.000000
0000469453 [app] INFO: temp=22.000000 hum=23.000000
0000471453 [app] INFO: temp=22.000000 hum=22.000000
0000473453 [app] INFO: temp=nan hum=23.000000
0000475453 [app] INFO: temp=nan hum=22.000000
If you really want to use the DHT11, the best solution is to use the DHT22Gen3_RK library.
Using that library instead produces rock-solid output because it uses the nRF52 I2S (sound) peripheral to sample the bits from the sensor using the hardware DMA peripheral so it’s unaffected by system interrupts.
0000054920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=20.0 tries=1
0000056920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000058920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000060920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000062920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000064920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000066920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000068921 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000070921 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=23.0 tries=1
0000072920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=24.0 tries=1
0000074920 [app] INFO: sampleResult=0 tempF=71.6 tempC=22.0 humidity=23.0 tries=1
Here’s the full source code:
#include "Particle.h"
#include "tracker_config.h"
#include "tracker.h"
#include "DHT22Gen3_RK.h"
#include "TemperatureHumidityValidatorRK.h"
SYSTEM_THREAD(ENABLED);
SYSTEM_MODE(SEMI_AUTOMATIC);
PRODUCT_ID(TRACKER_PRODUCT_ID);
PRODUCT_VERSION(TRACKER_PRODUCT_VERSION);
SerialLogHandler logHandler(115200, LOG_LEVEL_TRACE, {
{ "app.gps.nmea", LOG_LEVEL_INFO },
{ "app.gps.ubx", LOG_LEVEL_INFO },
{ "ncp.at", LOG_LEVEL_INFO },
{ "net.ppp.client", LOG_LEVEL_INFO },
// The two parameters are any available GPIO pins. They will be used as output but the signals aren't
// particularly important for DHT11 and DHT22 sensors. They do need to be valid pins, however.
DHT22Gen3 dht(A4, A5);
// Library: TemperatureHumidityValidatorRK
TemperatureHumidityValidator validator;
// Sample the temperature sensor every 2 seconds. This is done so the outlier values can be filtered out easily.
const unsigned long CHECK_PERIOD_MS = 2000;
unsigned long lastCheck = 0;
void locationGenerationCallback(JSONWriter &writer, LocationPoint &point, const void *context); // Forward declaration
Tracker::instance().init();
// Callback to add key press information to the location publish
Tracker::instance().location.regLocGenCallback(locationGenerationCallback);
// Initialize temperature sensor
dht.setup();
Particle.connect();
Tracker::instance().loop();
dht.loop();
if (millis() - lastCheck >= CHECK_PERIOD_MS) {
lastCheck = millis();
dht.getSample(A1, [](DHTSample sample) {
if (sample.isSuccess()) {
Log.info("sampleResult=%d tempF=%.1f tempC=%.1f humidity=%.1f tries=%d",
(int) sample.getSampleResult(), sample.getTempF(), sample.getTempC(), sample.getHumidity(), sample.getTries() );
// Log.info("dewPointF=%.1f dewPointC=%.1f",
// sample.getDewPointF(), sample.getDewPointC() );
validator.addSample(sample.getTempC(), sample.getHumidity());
else {
Log.info("sample is not valid sampleResult=%d", (int) sample.getSampleResult());
}, &DHT22Gen3::sensorTypeDHT11);
// Log.info("tempC=%f tempF=%f humidity=%f", validator.getTemperatureC(), validator.getTemperatureF(), validator.getHumidity());
float tempC = validator.getTemperatureC();
if (!isnan(tempC)) {
writer.name("temp").value(tempC, 2);
float hum = validator.getHumidity();
if (!isnan(hum)) {
writer.name("hum").value(hum, 1);
