DHT11 incorrect values [SOLVED]
Hello,
I am using the following code to get the temperature and humidity. I can see the values on the screen but are muioto different, for example atemperatura in degrees Celsius is now 17 but get 537.60.
The sensor is connected in
pin1 = VIN
pin2 = D2
pin3 nothing
pin4 GND
code:
#include "idDHT22/idDHT22.h"
// declaration for DHT11 handler
int idDHT22pin = D2; //Digital pin for comunications
void dht22_wrapper(); // must be declared before the lib initialization
// DHT instantiate
idDHT22 DHT22(idDHT22pin, dht22_wrapper);
	while(!Serial.available()) {
	    Serial.println("hit a key");
	    delay(1000);
	Serial.println("idDHT22 Example program");
	Serial.print("LIB version: ");
	Serial.println(idDHT22LIB_VERSION);
	Serial.println("---------------");
// This wrapper is in charge of calling
// mus be defined like this for the lib work
void dht22_wrapper() {
	DHT22.isrCallback();
	Serial.print("\nRetrieving information from sensor: ");
	Serial.print("Read sensor: ");
	//delay(100);
	DHT22.acquire();
	while (DHT22.acquiring())
	int result = DHT22.getStatus();
	switch (result)
		case IDDHTLIB_OK:
			Serial.println("OK");
			break;
		case IDDHTLIB_ERROR_CHECKSUM:
			Serial.println("Error\n\r\tChecksum error");
			break;
		case IDDHTLIB_ERROR_ISR_TIMEOUT:
			Serial.println("Error\n\r\tISR Time out error");
			break;
		case IDDHTLIB_ERROR_RESPONSE_TIMEOUT:
			Serial.println("Error\n\r\tResponse time out error");
			break;
		case IDDHTLIB_ERROR_DATA_TIMEOUT:
			Serial.println("Error\n\r\tData time out error");
			break;
		case IDDHTLIB_ERROR_ACQUIRING:
			Serial.println("Error\n\r\tAcquiring");
			break;
		case IDDHTLIB_ERROR_DELTA:
			Serial.println("Error\n\r\tDelta time to small");
			break;
		case IDDHTLIB_ERROR_NOTSTARTED:
			Serial.println("Error\n\r\tNot started");
			break;
		default:
			Serial.println("Unknown error");
			break;
	Serial.print("Humidity (%): ");
	Serial.println(DHT22.getHumidity(), 2);
	Serial.print("Temperature (oC): ");
	Serial.println(DHT22.getCelsius(), 2);
	Serial.print("Temperature (oF): ");
	Serial.println(DHT22.getFahrenheit(), 2);
	Serial.print("Temperature (K): ");
	Serial.println(DHT22.getKelvin(), 2);
	Serial.print("Dew Point (oC): ");
	Serial.println(DHT22.getDewPoint());
	Serial.print("Dew Point Slow (oC): ");
	Serial.println(DHT22.getDewPointSlow());
	delay(2000);
I guess if you’re using a DHT11 you ought to use a library for it an not its sibling DHT22.
There is a combined lib available, but then you have to initialize it correctly - look for PIETTETECH_DHT
thanks now works fine
