I have been getting compile errors when I move my toolchain to deviceOS@1.5.0-rc2. Here is an example from @rickkas7’s FRAM library. Note, I have seen this in other libraries as well so I think this is a general issue.
:::: COMPILING APPLICATION
Creating /Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/target/1.5.0-rc.2/boron/platform_user_ram.ld ...
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp: In member function 'virtual bool MB85RC::readData(size_t, uint8_t*, size_t)':
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp:68:58: error: call of overloaded 'requestFrom(int, size_t&, bool)' is ambiguous
wire.requestFrom(addr | DEVICE_ADDR, bytesToRead, true);
In file included from ../wiring/inc/spark_wiring_power.h:35:0,
from ./inc/application.h:46,
from ./inc/Particle.h:5,
from /Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp:2:
../wiring/inc/spark_wiring_i2c.h:109:10: note: candidate: size_t TwoWire::requestFrom(uint8_t, size_t, uint8_t)
size_t requestFrom(uint8_t, size_t, uint8_t);
../wiring/inc/spark_wiring_i2c.h:111:10: note: candidate: size_t TwoWire::requestFrom(int, int, int)
size_t requestFrom(int, int, int);
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp: In member function 'virtual bool MB85RC1M::readData(size_t, uint8_t*, size_t)':
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.cpp:203:54: error: call of overloaded 'requestFrom(int, size_t&, bool)' is ambiguous
wire.requestFrom(getI2CAddr(framAddr), count, true);
make[3]: *** [../build/target/user/platform-13-m/Boron-Connected-Counter/MB85RC256V-FRAM-RK/src/MB85RC256V-FRAM-RK.o] Error 1
make[2]: *** [user] Error 2
make[1]: *** [modules/boron/user-part] Error 2
make: *** [compile-user] Error 2
The terminal process terminated with exit code: 2
For now, I will go back to rc1 which compiles the same code without error.
I fixed the MB85RC256V-FRAM-RK; I just published version 0.0.5. I’m not really sure why it worked before because the receiveFrom call was ambiguous before as well.
Any chance I could ask you to do the same for your MCP79410 library?
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MCP79410RK/src/MCP79410RK.cpp: In member function 'int MCP79410::deviceRead(uint8_t, uint8_t, uint8_t*, size_t) const':
/Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MCP79410RK/src/MCP79410RK.cpp:777:69: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
count = wire.requestFrom(i2cAddr, (uint8_t) count, (uint8_t) true);
from /Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MCP79410RK/src/MCP79410RK.h:4,
from /Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/lib/MCP79410RK/src/MCP79410RK.cpp:1:
../wiring/inc/spark_wiring_i2c.h:111:10: note: candidate 1: size_t TwoWire::requestFrom(int, int, int)
../wiring/inc/spark_wiring_i2c.h:109:10: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, uint8_t)
text data bss dec hex filename
40288 420 1928 42636 a68c /Users/chipmc/Documents/Maker/Particle/Projects/Boron-Connected-Counter/target/1.5.0-rc.2/boron/Boron-Connected-Counter.elf
*** COMPILED SUCCESSFULLY ***
Thank you @rickkas7, I have been working with this library and and trying to figure out how to manage sleep with the Boron and an external real time clock.
This library is great and I look forward to getting better at using it to its full potential.
