Device OS 6.4.0 — Now GA
Device OS 6.4.0 is now Generally Available and the default for new device setup. This release has been validated with 18,000+ devices in production.
What’s new in 6.4.0?
Environment Variables support for Gen 3 + Gen 4
  • Adds device-level environment variables so you can change configuration without updating firmware
Faster startup with EARLY_INIT
  • New hook to run code earlier in the boot process, reducing startup time for time-sensitive apps
AM1805 RTC integration
  • First-class support for the AM1805
  • Enables RTC, watchdog, and ultra-low power timing capabilities for designs that include it
Power management improvements
  • Introduces power-off sleep mode
  • Supports ultra-low power and shipping mode use cases
Bug fixes
Fixes across connectivity, system behavior, and peripherals
Find the full release notes on GitHub: Device OS 6.4.0 release notes
