I was rushing to post - here are the warnings from the compile - nextTime
is declared as char nextTime[6];
-base.ino:19276:46: warning: '%02i' directive output may be truncated writing between 2 and 11 bytes into a region of size 6 [-Wformat-truncation=]
19276 | snprintf(nextTime, sizeof(nextTime), "%02i:%02i", _hr, _min);
-base.ino:19276:46: note: directive argument in the range [-1073741839, 1073741843]
-base.ino:19276:46: note: directive argument in the range [-30, 30]
-base.ino:19276:17: note: 'snprintf' output between 6 and 16 bytes into a destination of size 6
Always welcome your insight on these matters.
I can add that I have now seen the memory usage for 2.0.0-RC.4 is slightly less than 1.4.4 - so that is another +ve.
