Delay() does not work (accurately)
During debugging the DHT22 Lib I found out that the function delay(1) does not delay 1msec. To reproduce the error I wrote this short code for test.
    pinMode(A7, OUTPUT);
    digitalWrite(A7, LOW);
    delay(1);
    digitalWrite(A7, HIGH);
    delay(100);
The result ist this (video 2MB)
Oscilloscope, Timebase 200.0us
In words:delay(1) produces delays that are shorter than 1ms and the measured delay times jumps between 1ms to nearly zero.The delay gets shorter and shorter then jumps to a longer delay and get shorter again
I imagine this could be fixed in the firmware by having small delays <5ms delegate the handling to Delay_Microseconds() which is far more accurate.
Until then, you can replace delay(1) with Delay_Microseconds(1000) and check with your scope if is more accurate - I would expect it to have much less jitter and variance.
Yes, delayMicroseconds() works perfect.
Issue here: https://github.com/spark/core-firmware/issues/260
