Deep Sleep waking after only 3 seconds when should sleep for longer
Hi All,
Am I missing something silly?
I am trying to get the photon to Deep Sleep for 1 hour but it keeps waking after only a few seconds.
The code works fine with a fresh photon (with nothing wired to the board). However, when I connect my moisture sensor to the board the photon wakes after only a few seconds. Sensor is connected to GND VIN and A0 (DFRobot Capacitative Moisture Sensor). Photon powered via USB battery pack. I have also tried tying WKP Pin to ground using 3.7k resistor, but that didn’t help either?
Pulling my hair out here :slight_smile:
Code is:
#define SENSOR_PIN  A0
int led2 = D7;
int SensorLevel = 0;
  pinMode(led2, OUTPUT);
  pinMode(SENSOR_PIN, INPUT);
//**********************  Check moisture level and send to IFTTT *************
SensorLevel = analogRead(SENSOR_PIN);
//SensorLevel = 3000; //For testing
//SensorLevel = random(0,5000); //For testing
if (SensorLevel > 2750) {
    Particle.publish("WaterMeNow", String(SensorLevel), PRIVATE);
//LEDs flash for testing only
    digitalWrite(led2, HIGH);
    delay(200);
    digitalWrite(led2, LOW);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
else {
    Particle.publish("NotThirsty", String(SensorLevel), PRIVATE);
    delay(200);
    delay(200);
    delay(200);
  // Wait 0.5 minutes. For testing purposes to ensure I can reflash photon if necessary
delay(30000);
delay(1000);
System.sleep(SLEEP_MODE_DEEP, 60); //set to 60 seconds for test purposes only. Will change to 60min for real case
Cheers, and thanks in advance,
Steve
Could it be that your battery pack does something to the supply when the current draw from the Photon disapears?
A dip in USB supply voltage can also wake the device from deep sleep.
@ScruffR Thank you! I tried the computer USB as a power source and it is working fine now.
Much appreciated,
Steve
