The Particle reference states “The char datatype is a signed type, meaning that it encodes numbers from -128 to 127.”, which is OK for my application.
I intend to use char arrays and the array that I’ve declared doesn’t show any negative values at all; only the values between 0 and 127 are correctly shown;
For instance the value -100 is shown as 156 (so: 256 minus 100).
Do I have to do something special in declaring such a signed array?
(The declaration I use is nothing more than: char DATATB[622]
When you don’t want to store characters but numeric values you should probably best opt for a numeric data type like int8_t (signed 8bit integer) or uint8_t (unsigend 8bit integer) or even byte.
Then why do you care about the numeric values? Characters are unsigned or what would be the negative of A?
In memory an int8_t array is indistinguishable from a char array - so no need for conversion.
If you need to feed a “mistyped” array into a function that requires a different (but bit compatible) type you just use a type cast.
I understand that an int8_t array and a char array are indistinguishable in memory.
What I do not understand is what has been stated in the Particle Docs: “The char datatype is a signed type, meaning that it encodes numbers from -128 to 127.” because a char array that I have declared char DATATB[622] seems not to accept any negative numbers, only postive numbers.
So therefor my question is: should I do something additional to just declaring the array as I did.
Or how should I understand the Particle Docs?
The char data type is signed. However, depending on how you view it, it may appear as its unsigned equivalent. For example, if you use sprintf() with %u instead of %d.
However, given your declaration of an array of 622 characters, I’m guessing you’re using this for a publish. In this case, the rules of publish take precedence over the char data type. Publish only takes a null-terminated Unicode UTF-8 string, not an array of bytes. There is no equivalent of negative numbers in Unicode UTF-8.
If you are encoding binary data you must use some other encoding scheme like Base64 or Base85 that encodes binary data (including negative signed 8-bit values) in ASCII.
