Just a mental blockage - presumably it is at the wrong data type: I get the variable color_h not displayed; Unless I take the RGB value hard-coded into it.
#include <neopixel.h>
//SYSTEM_MODE(SEMI_AUTOMATIC)
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_COUNT 12
#define PIXEL_PIN D2
#define PIXEL_TYPE WS2812B
int brightness_h = 10; // 0-256 nonbright to bright
int brightness_m = 10; // 0-256 nonbright to bright
int delayval = 1000; // update scene
int min_px; // minute-pixel
int h; // hour
unsigned color_m; // minute-color
unsigned color_h; // hour-color
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE); // Instance the object
// Connects to a network with a specified authentication procedure.
// Options are WPA2, WPA, or WEP.
// WiFi.setCredentials("Ingo Heim", "PASSWORD", WPA2);
// WiFi.connect();
// while(Serial.read() < 0 && millis() < 10000) Particle.process(); // this waits here till you connect via Serial and hit a key (or max 10sec)
// if (!waitFor(WiFi.ready, 10000))
// Serial.println("Not able to connect to WiFi for 10sec");
// else
// Serial.print("Here we go SSID: ");
// Serial.println(WiFi.SSID());
Time.zone (+2.00); // setup a timezone > in this case Berlin
strip.begin();
/* the colors
* yellow - 128,128,0
* orange - 255,128,0
* red - 255,0,0
* green - 0,255,0
* blue - 0,0,255
* purple - 128,0,128
if (Time.hourFormat12() == 12) { // neopixel not count from 1-12 like the time-function. we need to change 12 o´clock to pixel 0
h = 0;
} else {
h = Time.hourFormat12(); // https://docs.particle.io/reference/firmware/photon/#hourformat12- - returns integer 1-12
Serial.println("**********VALIDATION HOUR******************************");
Serial.print("Device-Function: ");
Serial.println(Time.hourFormat12());
Serial.print("Hour: ");
Serial.println(h);
int m = Time.minute();
strip.clear(); // all already switched pixel turned off
if (m<5) {
min_px = 0; // 0 = first of in this case 12 pixel
color_m = (0,0,255); // blue
} else if (m >= 5 && m<10) {
min_px = 1;
} else if (m >= 10 && m<15) {
min_px = 2;
} else if (m >= 15 && m<20) {
min_px = 3;
} else if (m >= 20 && m<25) {
min_px = 4;
} else if (m >= 25 && m<30) {
min_px = 5;
} else if (m >= 30 && m<35) {
min_px = 6;
} else if (m >= 35 && m<40) {
min_px = 7;
} else if (m >= 40 && m<45) {
min_px = 8;
} else if (m >= 45 && m<50) {
min_px = 9;
} else if (m >= 50 && m<55) {
min_px = 10;
} else if (m >= 55) {
min_px = 11;
if (h==0) {
color_h = (0,255,0); // green
} else if (h==1) {
} else if (h==2) {
} else if (h==3) {
color_h = (255,128,0); // orange
} else if (h==4) {
} else if (h==5) {
} else if (h==6) {
color_h = (128,0,128); // purple
} else if (h==7) {
} else if (h==8) {
} else if (h==9) {
color_h = (0,0,255); // blue
} else if (h==10) {
} else if (h==11) {
if (h == min_px) {
Serial.println("***********EXCEPTION CASE: HOUR = Range of Minute-Pixel");
Serial.println(h);
Serial.print("Minute: ");
Serial.println(m);
Serial.print("Minute-Range: ");
Serial.println(min_px);
Serial.println("hour and minute-range is equal - you see 1 pixel bright");
strip.setPixelColor(h,128,128,0); // h: 1 Pixel in Yellow if hour and minute-range is equal
strip.setBrightness(brightness_h);
strip.show();
} else {
Serial.println("**********NORMAL CASE: HOUR <> Range of Minute-Pixel***");
Serial.println(h);
Serial.println(m);
Serial.println("hour and minute-range is NOT equal - you see 2 pixels bright");
**// Display Pixel - hardcoded version works, but color_h as variable not? Which data-type is correct to display (0,0,255)?**
strip.setPixelColor(h, color_h); // h: 1 Pixel **-> my problem here**
strip.show();
strip.setPixelColor(min_px, color_m); // min_px: 1 Pixel represents a period from 5 min
strip.setBrightness(brightness_m);
strip.show();
delay(delayval);
