works great
thx - code below:
// General code from http://www.pushingbox.com for Spark Core v1.0
//Example code for sending dynamic emails from the Core
//When creating Pushing Box scenario format email body somethinglike this: The $room$ temperature is $temperature$ degree
// MODIFY HERE //
// Your secret DevID from PushingBox.com. You can use multiple DevID on multiple Pin if you want
const char * DEVID1 = “insert-devid-from-pushingbox-here”; // Scenario: “The mailbox is open”
//declare variables to be sent here fx:-----------------
char room[] = “kitchen”;
uint8_t temp[] = 24;
// Numeric Pin where you connect your switch
uint8_t pinDevid1 = D0; // Example: the mailbox switch is connect to the Pin D0
// Debug mode
boolean DEBUG = true;
// End //
int LED = D7; // Built in LED
const char * serverName = “api.pushingbox.com”; // PushingBox API URL
boolean pinDevid1State = false; // Save the last state of the Pin for DEVID1
TCPClient client;
Serial.begin(9600); // Start the USB Serial
pinMode(pinDevid1, INPUT_PULLUP); // sets pin as Input PullUp, using the internal resistor. Connect PIN to GND.
pinMode(LED, OUTPUT); // sets LED as output
delay(1000);
// Prints out the network parameters over Serial
if(DEBUG){
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
Serial.print("Core IP: ");
Serial.println(WiFi.localIP());
Serial.print("Gateway: ");
Serial.println(WiFi.gatewayIP());
Serial.print("Mask: ");
Serial.println(WiFi.subnetMask());
Serial.print("WiFi RSSI: ");
Serial.println(WiFi.RSSI());
// Listening for the pinDevid1 state
if (digitalRead(pinDevid1) == HIGH && pinDevid1State == false) // switch on pinDevid1 is ON
if(DEBUG){Serial.println("pinDevid1 is HIGH");}
pinDevid1State = true;
// Sending request to PushingBox when the pin is HIGH
sendToPushingBox(DEVID1);
if (digitalRead(pinDevid1) == LOW && pinDevid1State == true) // switch on pinDevid1 is OFF
if(DEBUG){Serial.println("pinDevid1 is LOW");}
// Sending request to PushingBox when the pin is LOW
//sendToPushingBox(DEVID2); // Here you can run an other scenario by creating a DEVID2 variable
void sendToPushingBox(const char * devid)
digitalWrite(LED, HIGH); // sets the LED on
Serial.print(“closing… “);
client.stop();
if(DEBUG){Serial.print(“connecting… “);}
if (client.connect(serverName, 80)) {
if(DEBUG){Serial.println(“connected”);}
client.print(“GET /pushingbox?devid=”);
client.print(devid);
//put variables to be sent here:
client.print(”&room=”);
client.print(room);
client.print(”&temperature=”);
client.print(temp);
client.println(" HTTP/1.1");
client.print(“Host: “);
client.println(serverName);
client.println(“User-Agent: Spark”);
//client.println(“Connection: close”);
client.println();
if (DEBUG) {
Serial.print(“sent! - RSSI:”);
Serial.println(””);
while (!client.available()) SPARK_WLAN_Loop();
while (client.available()) {
char c = client.read();
Serial.print©;
Serial.println();
delay(150);
while(client.available()) {client.read();
digitalWrite(LED, LOW); // sets the LED off
else{
digitalWrite(LED, HIGH); // sets the LED on. If always on, last connexion was failed
if(DEBUG){Serial.println(“connection failed”);}
