Hi there!
I’m doing some tests with my Electron and a THIRD-PARTY sim (CTM - Macau).
The sw is basically a weather station that samples, send a String to the server and receives an ACK through UDP.
These are the important rows:
//#include "cellular_hal.h"
STARTUP(cellular_credentials_set("ctm-mobile", "", "", NULL));
SYSTEM_MODE(SEMI_AUTOMATIC);
bool wasConnected = false;
setup{ ..only sensors stuff... }
void loop(){
if(!Cellular.ready()){
Cellular.connect();
Serial.println("Connect");
delay(1000);
while(!Cellular.connecting()){
Serial.println("Connecting...");
delay(1000);
if( Cellular.ready() ){
if(!wasConnected){
Serial.println("Wasn't connected");
udp.begin(LOCAL_UDP_PORT); //60004 that is also server's port
wasConnected = true;
else{
Serial.println("wasConnected");
break;
else
wasConnected=false;
Serial.print("Connected: ");
int sentByte = udp.sendPacket((uint8_t *)udpBuffer, strlen(udpBuffer), REMOTE_UDP_ADDR, REMOTE_UDP_PORT); //60004
if(sentByte<0){
Serial.println("SendPacket error");
return;
int count = udp.receivePacket((uint8_t *)udpBuffer, UDP_BUFFER_SIZE - 1);
if (count > 0) {
Serial.println("OK");
else if (count == 0) {
Serial.printlnf("** No ACK %d", count);
else{
Serial.printlnf("** receivePacket error %d", count);
So, this sw above WORKS. In fact I get:
1 cycle:
BREATHING WHITE
BLINKING GREEN (Seconds)
BREATH GREEN
Connect
Connecting…
Wasn’t connected
Connected: 10.119.151.208
OK
2 cycle:
BREATH GREEN
Connecting…
wasConnected
OK
TEST 2:
In this second test I decided to “simulate” the disconnection/reconnection to the Cellular cell, using Cellular.connect() and .disconnect().
I put
//if(!Cellular.ready()) //Always connect at the beginning
Cellular.connect();
... (no edits from test 1)
if(sentByte<0){
Cellular.disconnect(); //Disconnect if send failed
wasConnected=false;
return;
Cellular.disconnect(); //Disconnect and restart loop
wasConnected=false;
Actually, this test has the weirdest behaviour:
1:
BREATHING WHITE
BL GREEN (Seconds)
Connect
GREEN BREATH
Connecting…
Wasn’t connected
Connected: 10.119.100.26
OK
2:
BL GREEN (on Connect()!! Blocking for 5.15min)
Connect
Blue BREATH
WHITE BREATH
Connecting…
GREEN BLINKING
Wasn’t connected
GREEN BREATH
OK
BLUE BREATHING
TEST 3 (and similars):
Now I would like to put into System.sleep(SLEEP_MODE_DEEP, 60, SLEEP_NETWORK_STANDBY), so, as the doc says, Keep cellular running. That means I shouldn’t need to connect() and udp.begin(PORT) again.
If I do that, the led is always breathing white and I can’t break from while(Cellular.connecting()).
If I connect() every restart, without udp.begin(PORT) the 2nd+ times, send fails.
If I connect() and udp.begin(PORT) everytime, I CAN SEND but I don’t receive the ACK.
1 CYCLE:
Connect
Connecting…
UDP begin…
Connected: 10.119.49.145
OK!
2 CYCLE:
Connect
Connecting…
UDP begin…
** No packets 0 (NO ACK!!!)
So, what’s the correct way to call Cellular functions?
Note that:
- I don’t have SYSTEM_THREAD(ENABLED). Actually the doc says to call udp.begin(LOCAL_PORT) after Cellular.ready() == true ONLY if system_thread is enabled. What about if is not enabled?
Actually If I also tried putting udp.begin(LOCAL_PORT) in setup(), I got IP from connect()/ready() but I can’t send any packets.
"If you are listening on a specific port (my case), you need to call begin(port) again every time the network is disconnected and reconnects, as well."
What about with system sleep? Is a disconnection/reconnection? Actually we saw as udp.beginning every sleeps prevent receiving acks.
- APN is correct. It doesn’t need credentials, so I didn’t include cellular_hal.h
Sorry for the long post.
