I have a problem with following code.
http://pastebin.com/BmgufZXf
Sometimes it just stops, cyan breathing, then cyan stuck, then reset to flashing green and working again. Repeat in 30-60 seconds.
Any advice on that?
Any advice on that?
This seems to be a common project nowadays
Just search zero_cross and you’ll find some more elaborate threads.
Another keyword in connection is SparkIntervalTimer
e.g. Alternative to Delay() within Interrupts?
But the short story - don’t use delays beyond a few microsec in an ISR!
A sidenote: digitalWriteFast() is way faster (but with less sanity checking) than digitalWrite() so it’s the way to do it inside an ISR.
Tried using code from here. [Solved] Trying to port an AC Dimmer circuit from Arduino to SparkCore
Well it works in a stable way, but it does not fully dim lights for me(only half-way) and have flickering issues even on incadesent bulbs. No such issues with original code.
While I’d still favour an aproach where you’d set up a SparkIntervalTimer with the dimming time to do the switching from within the zero-cross ISR, you could try this code, to see if your problem disapears
const int AC_LOAD = D7; // Output to Opto Triac pin
const int ZERO_DETECT = D4; // Input pin for the zero detection
const int PERIODE = 100; // 65 for 60Hz
const int DIM_DELAY = 20; // push dimming level every x ms
const int minDim = 5; // minimal dimming level
const int maxDim = 85; // maximal dimming level
int dimFact = +1; // dimming factor/direction
int dimming = minDim+1; // Dimming level (0-100)
pinMode(AC_LOAD, OUTPUT); // Set AC Load pin as output
pinMode(ZERO_DETECT, INPUT); // Set AC Load pin as output
attachInterrupt(ZERO_DETECT, zero_crosss_int, RISING);
uint32_t msDelay;
if (millis() - msDelay >= DIM_DELAY)
{ // every DIM_DELAY milli seconds push the dim level on
msDelay = millis();
dimming += dimFact; // inc/dec according to current direction/factor
dimming = constrain(dimming, minDim, maxDim);
if (minDim == dimming || dimming == maxDim)
dimFact *= -1; // invert dimming factor when bounds are reached
void zero_crosss_int() // function to be fired at the zero crossing to dim the light
// Firing angle calculation : 1 full 50Hz wave =1/50=20ms
// Every zerocrossing : (50Hz)-> 10ms (1/2 Cycle) For 60Hz (1/2 Cycle) => 8.33ms
// 10ms=10000us
delayMicroseconds(PERIODE*dimming); // Off cycle
pinSetFast(AC_LOAD); // triac firing
delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33)
pinResetFast(AC_LOAD); // triac Off
I replaced your delay()s with a non-blocking loop() design and streamlined your ISR a bit too.
Since you are not using WiFi, you could also consider SYSTEM_MODE(MANUAL).
@ryotsuke, this is an untested (due to missing hardware ;-)) version that uses the SparkTimerInterval library
#include "SparkIntervalTimer/SparkIntervalTimer.h"
IntervalTimer dimTimer;
dimTimer.begin(doDim, 100000, uSec); // just a dummy time
dimTimer.interrupt_SIT(INT_DISABLE); // don't fire now
uint32_t msDelay;
msDelay = millis();
// 10ms=10000us
// set up the timer for the actual dimming action
dimTimer.resetPeriod_SIT(PERIODE*dimming, uSec);
void doDim()
dimTimer.interrupt_SIT(INT_DISABLE); // only one-shot
I’d be interested how this actually does
There was something weird happening. First I made it dim 100% by using dim = 255 (with step of 77 that made double period)
When I decided to settle with that workaround it suddenly stopped working and original code with dim = 128 started to work fine.
It almost looks some changes in cloud were happening causing bad builds or something
Due to the way my code does the direction toggling you have to start the dimming within the allowed bounds. That’s what bounds are for
Yes, I understand that. However I could not reach fully dimmed state at 128, 0 -> 255 cycle did however work consinstently and from full light to full dimm. I can’t see why that was possible unless code built by cloud was calling timer interrupts twice faster or somthing like that, because eventually same code started to behave differently.
