To close the loop. The Photon friendly library can be found here: https://github.com/sazp96/Adafruit_HX8357_Library
My code is not pretty but it works
@machadolab I sent you a pull request. Hope it helps.
@sazp96
Awesome! I just added few comments that I think will allow the code to be a little cleaner and maintain compatibility with non-particle devices. If you can, could you make those changes and I will merge the pull request?
Thanks for doing this! Very helpful!
Thanks for the comments @machadolab. I made the changes and sent you a new pull request.
Cheers!
