Convert substring to integer
Hello
I know there are other posts detailing how this should work. Unfortunately I am missing something because they do not seem to work for me.
I am passing a numeric string e.g 109255125130 to my function, I am then using substring to parse out the elements for later usage (* this is not full code, just a snippet)
int ledToggle(String command) {
   String action=command.substring(0,1);
   String AAled=command.substring(1,3);
   String red=command.substring(3,6);
   String green=command.substring(6,9);
   String blue=command.substring(9);
I then need to convert the substring ‘part’ into an actual integer so
   int lednum = 0;
   lednum = AAled.toInt();
At this point (along with the remaining parts of the code), compiling completes without issue. no errors.
However, if I then attempt to use ‘lednum’ as a component in additional downstream processing such as
Particle.publish(“actionXX”, lednum, PRIVATE);
I get “invalid conversion from ‘int’ to ‘const char*’ [-fpermissive]”; I do not understand the error, nor how to go about fixing it.
Can anyone put me out of my misery please?
Tony
** please ignore the above request **. I just got it to work. The specific error from the original post relates to the an issue with particle.publish and is not the actual thing I am looking to do
Would be nice if you can post how you fixed it so others can benefit from your findings.
FYI: https://docs.particle.io/reference/device-os/firmware/photon/#particle-publish-
Particle publish expects a String, not an integer as far as I’m aware.
quite so. please reference Json post payload particle.function for complete picture
lednum not declared as a global variable would not help!
