Control Smart Config mode [SOLVED]
After read several topics talking about the possibility of control the smart config mode, i’m not clarify how i get full control of smart config process.
I want to activate the smart config for a period of time and then if there wasn’t any device to set new SSID and wifi key, i want to turn it off.
I’m already able to enter in smartconfig mode during my code activating the flag WLAN_SMART_CONFIG_START, there is any timeout configuration or any away to stop the smart config mode, or it’s really needed to change the bootloader as refereed by @kennethlimcp in this topic: https://community.spark.io/t/is-there-a-way-to-set-wlan-smart-config-start-and-continue-running-my-code/5048
Look at docs.spark.io there’s a function call to enter Listening mode but I’m on mobile so I can’t paste the syntax :wink:
hi @kennethlimcp, are you talking of the function WiFi.listen() in spark_wiring_wifi.h referred here:
Yes i think that should work! http://docs.spark.io/firmware/#wifi-listen
I had to implement a timeout at work. Unrolling all the calls didn’t seem to lend itself as an easy solution, so I changed the while() loop in Start_Smart_Config() in core-firmware/src/spark_wlan.cpp. I only wanted to time out if there were credentials, and I found an easy way to reset was to do a deep sleep for 1 second. Get into listen mode as described above; these changes will reset the core after 5 minutes if the core has credentials (remove the tests if you don’t need that feature).
 void Start_Smart_Config(void)
+    unsigned long SCtimeout;
+    boolean EnableSCtimeout = false;
     WLAN_SMART_CONFIG_FINISHED = 0;
     WLAN_SMART_CONFIG_STOP = 0;
     WLAN_SERIAL_CONFIG_DONE = 0;
     WLAN_CONNECTED = 0;
     WLAN_DHCP = 0;
     WLAN_CAN_SHUTDOWN = 0;
     SPARK_CLOUD_SOCKETED = 0;
     SPARK_CLOUD_CONNECTED = 0;
     SPARK_FLASH_UPDATE = 0;
     SPARK_LED_FADE = 0;
     LED_SetRGBColor(RGB_COLOR_BLUE);
     LED_On(LED_RGB);
     WiFi.disconnect();
     /* Create new entry for AES encryption key */
     nvmem_create_entry(NVMEM_AES128_KEY_FILEID,16);
     /* Write AES key to NVMEM */
     aes_write_key((unsigned char *)(&smartconfigkey[0]));
     wlan_smart_config_set_prefix((char*)aucCC3000_prefix);
     /* Start the SmartConfig start process */
     wlan_smart_config_start(1);
     WiFiCredentialsReader wifi_creds_reader(wifi_add_profile_callback);
     /* Wait for SmartConfig/SerialConfig to finish */
+    SCtimeout = millis() + 5*60*1000;           // set timeout to 5 minutes in the future
+    EnableSCtimeout = WiFi.hasCredentials();    // enable timeout only if I have credentials
     while (WiFi.listening())
         if(WLAN_DELETE_PROFILES)
             int toggle = 25;
             while(toggle--)
                 LED_Toggle(LED_RGB);
                 Delay(50);
             WiFi.clearCredentials();
             WLAN_DELETE_PROFILES = 0;
+            EnableSCtimeout = false;            // I no longer have credentials so don't timeout
         else
             Delay(250);
             wifi_creds_reader.read();
+        // reset if I have I have credentials and I've been here too long
+        if( EnableSCtimeout && ((long)(millis() - SCtimeout) >= 0) )
+            Spark.sleep(SLEEP_MODE_DEEP,1);
     LED_On(LED_RGB);
@kennethlimcp, this function WiFi.listen() simply activate the flag to call the smartconfig mode, it doesn’t control the process.
@ScottR, I use some inspiration in your code, and using the last core-firmware from the master branch, i adjust it. Because i don’t want to reset the core to stop the smartconfig process, so i implement this way:
+   int time_out= 20000; // milliseconds
+   bool EnableSCtimeout = false;
+   bool stop_smartConfig= false;
	WLAN_CONNECTED = 0;
	WLAN_DHCP = 0;
	SPARK_LED_FADE = 0;
	LED_On(LED_RGB);
	WiFi.disconnect();
+    SCtimeout = millis() + time_out;    // Define timeout
			int toggle = 25;
			while(toggle--)
				Delay(50);
		else
			Delay(250);
+       if( EnableSCtimeout && ((long)(millis() - SCtimeout) >= 0) ){
+            stop_smartConfig=true;
+            break;
   LED_On(LED_RGB);
+    if(stop_smartConfig){
+        wlan_smart_config_stop();
+    } else {
        /* read count of wlan profiles stored */
        nvmem_read(NVMEM_SPARK_FILE_ID, 1, WLAN_PROFILE_FILE_OFFSET, &NVMEM_Spark_File_Data[WLAN_PROFILE_FILE_OFFSET]);
        if(WLAN_SMART_CONFIG_FINISHED)
            /* Decrypt configuration information and add profile */
            SPARK_WLAN_SmartConfigProcess();
	WiFi.connect();
	WLAN_SMART_CONFIG_START = 0;
I will perform more tests to check if its working properly. Because i’m using semi-automatic mode and i have some issues: https://github.com/spark/core-firmware/issues/310
