Control NeoPixel Strip over the web
#Piggy’s LED Playground
A simple web integrated suite of apps that allow a WS2812 strip to be controlled.
##Features
  • REST API (useful for IFTTT etc)
  • Responsive web app
  • Multiple Animations with different options
  • Token protection
##Animations
  • All animations in Loop-Mode or fixed number of cycles
  • KnightRider:
    • Video
    • Options: Length of trail (for fadeout), Speed, Cycles, Color
  • ColorWipe:
    • Video
    • Options: Speed, Cycles
  • RainbowFade:
    • Video
    • Options: Speed, Cycles, Brightness
  • RainbowPattern:
    • Video
    • Options: Speed, Cycles, Density (Number of Rainbows per strip), Brightness
  • SparkleColors:
    • Video
    • Options: Density, Speed, Cycles, Color or Random Colors
##ToDo / Possibilities
  • Optimize Code of Spark Core. Enough places for better memory usage, faster animation calculations
  • Make API smarter (e.g. Log all animations to database for ‘most used animations settings’ or stats for each caller by different tokens)
  • More animations:
    • MorseCode, input a text and show a ticker with Morse code
    • HeartBeat/Breath, animate a single color by brightness to look like heartbeating or breathing
    • ColorFade, fade between multiple colors (instead through the complete rainbow)
  • Integrate services (e.g. with IFTTT or other APIs), “new mail, cyan Knightrider”, “facebook notification, blue blinking”, etc
  • Combine with an alarmclock for visual alarm
##Requirements
  • Spark Core (Spark Photon not tested)
  • WS2812B LED Strip (other Adafruit NeoPixel-Compatible LEDs might work)
  • Web server with PHP >= 5.3.0
##Configurations / Installation
  • Spark Core:
    • Pin, LED Count, LED Type
  • PHP:
    • Spark Device ID and Spark Access Token (inside function sendPost())
    • Token for API (inside function setDefaultConditions())
##Acknowledgement / Used Libraries
##Download
Thank you.
Best wishes.
Did you just hook up your Core D2 to input of your NeoPixel Strip and used VCC and GND from the Core?
