I have a Photon and a Phobot shield which I’m trying to use to control a 4-pin CPU fan. If you’re not familiar with these fans, the pins are +12V, GND, a PWM input for controlling the speed and a tach output for reading it back.
I’ve got the fan wired up as follows: +12V and GND are connected to the M1 screw terminals, which are controlled by a FET on D7, and the PWM input is connected to the D4 pin via the “T” pinout for the sonar. Yes, I know D4 is not a PWM pin… I’ll probably jump it to another pin that is, but for now I’ve got a voltage issue.
My issue is this: the fan internally contains a pullup resistor between a +5V source and the PWM. If I put D4 in high impedance and turn on the fan, I see about ~4.5V on the pin. If I pull D4 low, the voltage stays the same - the pin can’t pull the line down by any amount I can detect.
Figuring that the +5V in the fan comes from a voltage divider, I measured resistances:
* GND to PWM is around 100k
* PWM to +12V is around 10M
* GND to +12V is around 10M
Any suggestions? I can’t understand why the D4 pin can’t pull down the line - the specs on PWM fans say you need to be able to sink a couple of mA, it shouldn’t be a problem…
