Dear all,
I dont understand why my relay click in both cases: also if brightness light of lower and higher then 10.
Do I have a problem with my control structure if/else? Check pls (light < lightgrenze). Thx for your feedback!
#include <blynk.h>
// Quelle: http://diotlabs.daraghbyrne.me/7-communicating-events/pir/
// https://learn.adafruit.com/pir-passive-infrared-proximity-motion-sensor/using-a-pir
// https://gist.github.com/zsup/9496462
// http://community.garadget.com/t/instructions-for-home-grown-garadget-clone/69 --> Relay Belegung und Schaltung
int inputPin = D0; // choose the input pin (for PIR sensor)
int ledPin = D1; // LED Pin
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
int boardLed = D7; // photon onBoard LED
int boardRelay = D2; // Relay
int calibrateTime = 10000; // wait for the thingy to calibrate
int light; // Wert des aktuellen Lichts
int lightgrenze = 10; // Schwellwert bei dem Dunkelerheit erkannt und Licht eingeschaltet werden soll
int light_sensor_pin = A0;
char auth[] = "123"; // photon2
// Start Blynk
//Serial.begin(115200);
Blynk.begin(auth);
pinMode(boardLed,OUTPUT); // on-board LED
pinMode( ledPin, OUTPUT );
pinMode(inputPin, INPUT); // declare sensor as input
pinMode(boardRelay,OUTPUT); // declare Relay
// Now flash the D7 LED on and off
digitalWrite(boardLed,HIGH); // Start der Kallibrierung mit D7 on
Particle.publish("PIR-Status","now online",100,PRIVATE);
digitalWrite(boardLed,LOW); // Start der Kallibrierung mit D7 off
// Start Blynk
Blynk.run();
// if the sensor is calibrated
if ( calibrated() )
// get the data from the sensor
readTheSensor();
// report it out, if the state has changed
reportTheData();
void readTheSensor() {
val = digitalRead(inputPin);
bool calibrated() {
return millis() - calibrateTime > 0;
void reportTheData() {
// if the sensor reads high
// or there is now motion
if (val == HIGH) {
// the current state is no motion
// i.e. it's just changed
// announce this change by publishing an event
if (pirState == LOW) {
// we have just turned on --> es wurde zwar auf Wärme hin detektiert und gefunden, jedoch wird nur bei geringem Umgebungslicht der LED Streifen angeknipst.
Particle.publish("PIR-Status","motion detected", 60, PRIVATE);
// ĂberprĂźfung der Hellingkeit, da nur im Dunkeln der LED Streifen einzuschalten ist
float light_measurement = analogRead(light_sensor_pin);
light = (int(light_measurement/4096*100));
delay(300);
Particle.publish("light", String(light), PRIVATE);
Blynk.virtualWrite(V1, String(light));
if (light < lightgrenze) {
Particle.publish("light","Licht an", PRIVATE);
// Update the current state
pirState = HIGH; // hang tight here until motion stops
setLED( pirState ); // Aufruf der Funktion unten mit (An-)Schaltung des Relays
//digitalWrite(boardLed,HIGH);
//delay(1000);
//digitalWrite(boardLed,LOW);
//digitalWrite(boardRelay, HIGH);
delay(15000); // Leuchtdauer
//digitalWrite(boardRelay, LOW);
return;
else {
Particle.publish("light","Licht ist aus", PRIVATE);
return;
} else {
if (pirState == HIGH) {
// we have just turned of
pirState = LOW;
setLED( pirState );
void setLED( int state )
digitalWrite(ledPin,state);
digitalWrite(boardLed,state);
digitalWrite(boardRelay,state);
to 1.) yes, the relay engages in both cases: if light is < and > threshold âlightgrenzeâ (in my case 10).
to 2.) After the detection, the ambient light is measured and the threshold value is used to determine whether the relay closes the circuit for a lamp or leaves it open.
In my case, however, the relay always closes. It makes me confused.
What do you see in the console logs? Is âParticle.publish(âlightâ,âLicht anâ, PRIVATE);â firing everytime motion is detected? if so, can you log the values of light and lightgrenze?
I got this error
/src/mypir.cpp:89:66: error: invalid conversion from âintâ to âconst char*â [-fpermissive]
I tested code with this command:if (light < lightgrenze) {
Particle.publish(âPIR-light into ifâ,âLicht anâ, PRIVATE);
Particle.publish(âPIR-light into if valueâ, light, PRIVATE);
Particle.publish(âPIR-light in if thresholdâ, lightgrenze, PRIVATE);
The control structure works in general; I got this error as I changed the publish event:
Particle.publish(âPIR-light into if valueâ, String(light), PRIVATE);
It might be that I have a problem with chars and values.
Now I tested
Particle.publish(âPIR-light into if thresholdâ, String(lightgrenze), PRIVATE);
delay(300); // only 1 value of actual brightness is necessary to decide in the if clause
Particle.publish("PIR-light vorher", String(light), PRIVATE);
Particle.publish("PIR-light into if","Licht an", PRIVATE);
Particle.publish("PIR-light into if value", String(light), PRIVATE);
Particle.publish("PIR-light into if threshold", String(lightgrenze), PRIVATE);
return;
else {
Particle.publish("PIR-light into if","Licht ist aus", PRIVATE);
return;
} else {
pirState = LOW;
setLED( pirState );
Particle.publish("PIR-light before if","Licht an", PRIVATE);
Particle.publish("PIR-light before if value", String(light), PRIVATE);
Particle.publish("PIR-light before if threshold", lightgrenze, PRIVATE);
case1: Particle.publish("PIR-light before if threshold", **String(lightgrenze**), PRIVATE);
= no console log entry
case2: Particle.publish("PIR-light before if threshold", lightgrenze, PRIVATE);
= fire this error in console log:
/src/mypir.cpp:88:81: error: invalid conversion from 'int' to 'const char*' [-fpermissive]
In file included from ../wiring/inc/spark_wiring.h:48:0,
from ./inc/application.h:36,
from /src/mypir.cpp:2:
../wiring/inc/spark_wiring_cloud.h:227:17: error: initializing argument 2 of 'bool CloudClass::publish(const char*, const char*, PublishFlag)' [-fpermissive]
inline bool publish(const char *eventName, const char *eventData, PublishFlag eventType=PUBLIC)
make[1]: *** [../build/target/user/platform-6src/mypir.o] Error 1
make: *** [user] Error 2
Im crying - its a simple if/else statement.
want light in the dark (relay closed, lamp on).
if it is daylight - no lamp is necessary.
You should incorporate your three publishes into just one, to avoid hitting the rate limit of 1/sec.
Particle.publish("PIR-light before if",String::("Licht an (%d/%d)", light, lightgrenze), PRIVATE);
And instead of
Iâd rather write
light = ((100*light_measurement)/4095));
Since all your variables and number literals are int you will only get an int division and since any analogRead() result will be less or equal 4095 a division by 4096 will always result in 0.
And int() does not round but truncate, so even int(0.999999) would still give you 0.
Thanks for your feedback. Probably I have a fundamental error in the construction of the experiment with the light sensor. This throws values above the threshold value in darkness and therefore the relay switches. The if / else construct works.
