Console Log Reporting Battery "Charged" at low voltage (67%)
I am running a Electron E-Series board with a Li-Ion battery pack and a solar panel to charge. For some reason the Particle Console is reporting “charged” at 67%. I see similar charged flags from the PMIC status despite the VCell being 3.8V instead of 4.2. What is causing this discrepancy?
Probably your solar panel can’t handle
Just curious how is the current and voltage from panel during a clean sun and how the panel parm. are affected by clouds :cloud:?
Here are the specs, its been a while since i checked cloudy readings but that shouldnt affect the PMIC status or the VCell reading should it?
  • Open Circuit Voltage: 7.13V
  • Peak Voltage: 6.12V
  • Peak Current: 940mA
  • Peak Power: 5.75W
  • Power Tolerance: +/-10%
