Connecting Photon to Adafruit TPA2016D2
Hello there,
I would like to build a small cloud connected mp3 player.
I got:
I’ve checked in Particle library but I found nothing for the Adafruit TPA2016D2.
Do you have any suggestion about how to proceed to connect to the Photon and use the Adafruit TPA2016D2?
Thanks for your time :slight_smile:
How about this?
Quickly skimming over the code that should work out the box
How can I import that in Particle online IDE?
To start with, you’d add some file tabs to your project (top right corner (+) icon) and copy paste the library code into these.
