Is it possible to send data to custom server?
For example “api.myserver.com”, port 80
client.connect(“api.myserver.com”, 80);
client.println(“GET /api.php?data=dev:XX;rt:XX;h:XX;t:XX; HTTP/1.1”);
Any help? Is there any documentation for this?
Hi @sanwin
I think that what you want to do should be easy. Here is some code that I use. You may have to % escape the XX fields in the URL.
void sendGetRequest(const char * server, const char * url)
if (myTCP.connect(server, 80)) {
//Serial1.print("Connected to Server");
digitalWrite(D7,HIGH);
myTCP.print("GET ");
myTCP.print(url);
myTCP.println(" HTTP/1.0");
myTCP.println("Connection: close");
myTCP.print("Host: ");
myTCP.println(server);
myTCP.println("Accept: text/html, text/plain");
myTCP.println();
myTCP.flush();
Thanks, working now!
