From what I can see, this is what happens when a webhook succeeds. Didn’t find it in the docs. I hope it will be helpful. I also created a pull request to update the docs.
Confirming that a webhook succeeded
You will know that your webhook succeeded if you see the following pattern on your event stream (using Particle CLI command particle subscribe mine
{"name":"name_of_my_event","data":"data_sent_with_event","ttl":"60","published_at":"2016-04-16T13:37:08.728Z","coreid":"1234567890987654321"}
{"hook-sent/name":"name_of_my_event","data":"undefined","ttl":"60","published_at":"2016-04-16T13:37:08.743Z","coreid":"particle-internal"}
{"name":"hook-response/name_of_my_event/0","data":"ok","ttl":"60","published_at":"2016-04-16T13:37:08.755Z","coreid":"particle-internal"}
Explanation:
- The first line is logged when you call
Particle.publish()
in your firmware. - The second line (
hook-sent
) confirms that the Particle cloud was able to reach the endoint URL of the webhook - The third line (
hook-response
) means that a response was received. The event handler attached by theParticle.subscribe()
function in your firmware should be called.
