It compiles without error in Arduino and Engeria.
In both cloud and Particle Dev, it fails with:
crap.cpp:5:1: error: expected unqualified-id before 'else’
else if (res & 2);
It sure looks lik good C/C++ to me. Any insights?
Al
int res, rr;
if (res & 1)
rr = 1;
else if (res & 2)
rr = 2;
That C code compiles here without error. No C++ syntax used. File name is .cpp so compiler will treat it as C++.
Perhaps you have a non-printable character within the source?
(PS: your question has an unrelated error with the semicolon after (res & 2).
Also, most compilers will give a warning that res has no value assigned before its first use.
It is the Particle/Arduino preprocessor that is messing you up. This is the nice part of Arduino-land that lets you avoid function prototypes for forward references and lots of other stuff, but it is messed up by single statement if’s.
You can turn it off (and then write strictly in C/C++) with this at the top of your file:
#pragma SPARK_NO_PREPROCESSOR
You can also make it compile by adding curly braces around the else clause so it is no longer a single statement:
