Hello All,
So I’ve finally hit the wall of running out of APP_FLASH. I was looking into custom compiler flags to reduce the app binary size(e.g. https://stackoverflow.com/questions/15314581/g-compiler-flag-to-minimize-binary-size). Just wondering if anyone has any experience in doing this for particle.
I’ve read a view form posts about this and I do know that I need to build this locally.
With Device OS 2.0.0 you’ll need to modify the Workbench Makefile to add the COMPILE_LTO=y option to the options for building the user firmware binary. For example, for the compile and flash target:
# Compile and flash the user part
flash-user: dfu preprocess
$(call print_stage,FLASHING APPLICATION)
cd "$(value DEVICE_OS_PATH)/main" && make all program-dfu COMPILE_LTO=y
$(call print_success,FLASHED SUCCESSFULLY)
This only works with 2.0.0-rc and later. Make sure you Clean application after changing the value. This will also increase the time spent in the link phase, but it will make the binary smaller.
@rickkas7 thanks for the reply.
Good to know there is an option. I see that v2.0.0-rc.4 just got release today. I’ll try this out.
Do we have an approximate/tentative ETA on when v2.0.0+ will move out of the RC phase?
Sorry for the lame question. I cannot find how to edit the Workbench Makefile to add this COMPILE_LTO=y flag. Can I ask for a tip here please?
I think this will be in the particle tool chain folder. OS 2.0.0 just released a few days ago so I was thinking of giving this a shot sometime next week.
Tool chain folder in windows is probably in the path:
C:\Users\<UserName>\.particle\toolchains\buildscripts
Make sure you download the OS 2.0.0 toolchain and it should appear in that folder
@rickkas7 correct me if I am wrong. I “THINK” this is what we should do. Note I am not too sure which “exact” folder it is as well.
It seems that location is correct. I implemented the changes suggested. However, the binary size of my app didn’t changed after all. On the other hand the size of the binary reduced a couple of kB after I migrated from 1.5.2 to 2.0.0.
Cheers!
/G
@rickkas7 did mention that the device’s OS will have to be 2.0.0 so I guess this will explain the size only changing upon upgrading.
Glad to see you got some results!
