Code Works on Arduino, but not Photon?
else if(digitalRead(buttonPin) == 0){            //Door Closed
    digitalWrite(ledPin, LOW);
    x = 1;
    Serial.println(digitalRead(buttonPin));            //Prints 0
    delay(100);
because you are not looking for the state change in the above else if statement.
but you are here:
if ((digitalRead(buttonPin) == 1) && (x == 1))
recommend that you use a non-blocking version like this (untested):
const int ledPin = D7;
const int buttonPin = D0;
const int debounceTime = 50;
void setup()
  pinMode(buttonPin, INPUT_PULLUP);
  pinMode(ledPin, OUTPUT);
void loop()
  int pressed = checkButton(buttonPin);
  switch(pressed)
    case 1:
      Serial.println("Door Closed");
      // send message here
      break;
    case 2:
      Serial.println("Door Open");
      digitalWrite(ledPin, HIGH);
      break;
    default:
      // nothing to do here
      break;
int checkButton(int pin)
  static unsigned long lastTime = 0;
  static bool lastState = false;
  bool state = digitalRead(pin);
  if(state != lastState && millis() - lastTime > debounceTime)
    return state? 2 : 1;
    lastTime = millis();
  return 0;
