Can someone help me figure out why this is happening.
#include <PietteTech_DHT.h>
#define DHTTYPE DHT11 // Sensor type DHT11/21/22/AM2301/AM2302
#define DHTPIN D0 // Digital pin for communications
#define DHT_SAMPLE_INTERVAL 3000 // Sample every 3 seconds
#define RELAY1 A0
#define RELAY2 A1
#define RELAY3 A2
#define RELAY4 A3
SYSTEM_MODE(AUTOMATIC);
SYSTEM_THREAD(ENABLED);
double humidity,temp,dewpoint = 0;
String fanStatus = "OFF";
bool manualRun = false;
int humidityTreshold = 65;
PietteTech_DHT DHT(DHTPIN, DHTTYPE);
//DHT22 requires pullup
pinMode(DHTPIN, INPUT_PULLUP);
//Initilize the relay control pins as output
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
// Initialize all relays to an OFF state
digitalWrite(RELAY1, LOW);
digitalWrite(RELAY2, LOW);
digitalWrite(RELAY3, LOW);
digitalWrite(RELAY4, LOW);
Particle.function("fan", fancontrol);
Particle.variable("temp", temp);
Particle.variable("humidity", humidity);
Particle.variable("dewpoint", dewpoint);
Particle.variable("fanStatus", fanStatus);
//Serial.begin(9600);
DHT.begin();
measure();
if(humidity >= humidityTreshold && (fanStatus == "OFF"))
turnOnFan();
if(humidity < humidityTreshold && (fanStatus == "ON") && !manualRun)
turnOffFan();
/*Serial.print("Humidity (%): ");
Serial.println(humidity, 2);
Serial.print("Temperature (oC): ");
Serial.println(temp, 2);
Serial.print("Dew Point Slow (oC): ");
Serial.println(dewpoint);*/
//connect();
delay(DHT_SAMPLE_INTERVAL);
int fancontrol(String command) {
if ((fanStatus == "ON") && command == "OFF") {
manualRun = false;
turnOffFan();
if ((fanStatus == "OFF") && command == "ON") {
manualRun = true;
turnOnFan();
return 1;
void publishEvent(String eventName, String data) {
//connect();
Particle.publish(eventName,data,PRIVATE);
void connect() {
if (Particle.connected() == false) {
Particle.connect();
void turnOnFan() {
digitalWrite(RELAY1,HIGH);
fanStatus = "ON";
publishEvent("fan","on");
void turnOffFan() {
digitalWrite(RELAY1,LOW);
fanStatus = "OFF";
publishEvent("fan","off");
void measure() {
int result = DHT.acquireAndWait(2000);
switch (result) {
case DHTLIB_OK:
humidity = DHT.getHumidity();
temp = DHT.getCelsius();
dewpoint = DHT.getDewPointSlow();
break;
case DHTLIB_ERROR_CHECKSUM:
publishEvent("error","DHT read: Checksum error");
//Serial.println("Error\n\r\tChecksum error");
break;
case DHTLIB_ERROR_ISR_TIMEOUT:
publishEvent("error","DHT read: ISR time out error");
//Serial.println("Error\n\r\tISR time out error");
break;
case DHTLIB_ERROR_RESPONSE_TIMEOUT:
publishEvent("error","DHT read: Response time out error");
//Serial.println("Error\n\r\tResponse time out error");
break;
case DHTLIB_ERROR_DATA_TIMEOUT:
publishEvent("error","DHT read: Data time out error");
//Serial.println("Error\n\r\tData time out error");
break;
case DHTLIB_ERROR_ACQUIRING:
publishEvent("error","DHT read: Acquiring");
//Serial.println("Error\n\r\tAcquiring");
break;
case DHTLIB_ERROR_DELTA:
publishEvent("error","DHT read: Delta time to small");
//Serial.println("Error\n\r\tDelta time too small");
break;
case DHTLIB_ERROR_NOTSTARTED:
publishEvent("error","DHT read: Not started");
//Serial.println("Error\n\r\tNot started");
break;
default:
publishEvent("error","DHT read: Unknown error");
//Serial.println("Unknown error");
Compiler Error
Building target: target/workspace.elf
Invoking: ARM GCC C++ Linker
mkdir -p target/
arm-none-eabi-g++ -DSTM32_DEVICE -DSTM32F10X_MD -DPLATFORM_THREADING=0 -DPLATFORM_ID=0 -DPLATFORM_NAME=core -DUSBD_VID_SPARK=0x1D50 -DUSBD_PID_DFU=0x607F -DUSBD_PID_CDC=0x607D -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -flto -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=0 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DMBEDTLS_CONFIG_FILE="<mbedtls_config.h>" -DSYSTEM_VERSION_STRING=1.1.0 -DRELEASE_BUILD -Werror -I../user/inc -I../wiring/inc -I../hal/inc -I../hal/shared -I../hal/src/core -I../hal/src/stm32 -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/src -I../platform/shared/inc -I../platform/MCU/STM32F1xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F1xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F1xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F1xx/CMSIS/Include -I../platform/MCU/STM32F1xx/CMSIS/Device/ST/Include -I../platform/NET/CC3000/CC3000_Host_Driver -I../crypto/inc -I../third_party/mbedtls/mbedtls/include -I../dynalib/inc -I. -MD -MP -MF target/workspace.elf.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DMODULE_VERSION=1102 -DMODULE_FUNCTION=3 -DMODULE_DEPENDENCY=0,0,0 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE target/obj/./src/module_info.o target/obj/startup/startup_stm32f10x_md.o --output target/workspace.elf -nostartfiles -Xlinker --gc-sections -flto -Os -fuse-linker-plugin -Tlinker_stm32f10x_md_dfu.ld -L../build/arm/linker --specs=nano.specs -lc -lnosys -u _printf_float -Wl,-Map,target/workspace.map -L../build/target/user/platform-0-lto -L../build/target/wiring/platform-0-lto/ -L../build/target/system/platform-0-lto/ -L../build/target/services/platform-0-lto/ -L../build/target/communication/platform-0-lto-prod-0/ -L../build/target/hal/platform-0-lto/ -L../build/target/platform/platform-0-lto/ -L../build/target/wiring_globals/platform-0-lto/ -L../build/target/crypto/platform-0-lto/ -L../build/target/newlib_nano/platform-0-lto -L../build/target/miniz/platform-0-lto -L../build/target/nanopb/platform-0-lto -L../build/target/mbedtls/platform-0-lto -L../build/arm/linker -Wl,--whole-archive -lnewlib_nano -luser -lwiring -lhal -lsystem -lservices -lcommunication -lplatform -lwiring_globals -lcrypto -lminiz -lnanopb -lmbedtls -Wl,--no-whole-archive
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: target/workspace.elf section `.text' will not fit in region `APP_FLASH'
/usr/local/gcc-arm-embedded/bin/../lib/gcc/arm-none-eabi/5.3.1/../../../../arm-none-eabi/bin/ld: region `APP_FLASH' overflowed by 3592 bytes
../build/module.mk:232: recipe for target 'target/workspace.elf' failed
make: *** [target/workspace.elf] Error 1
