Hello guys,
I am using adafruit Neopixel library to blink led, i want to create different color patterns (blinks) to indicate statuses … I did that below …and it work … but I think there are more efficient ways to do the same.
will be great if any of you can give me hint how I can achieve that in more efficient way .
below is a piece of code of how I am doing that now.
#include "Particle.h"
#include "neopixel.h"
// IMPORTANT: Set pixel COUNT, PIN and TYPE
#define PIXEL_PIN D2
#define PIXEL_COUNT 1 // for now just one led (I may require use 2 led is necessary)
#define PIXEL_TYPE WS2811
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
int red;
int green;
int blue;
int white;
int clear_led;
strip.begin(); // Initialize strip
strip.show(); // (R, G, B) // Update all LEDs (= turn OFF, since none of them have been set yet!)
red = strip.Color(255, 0, 0); // Red
green = strip.Color(0, 255, 0); // Green
blue = strip.Color(0, 0, 255); // Blue
white = strip.Color(243, 63, 193); // White was (0,255,100)
clear_led = strip.Color(0, 0, 0); // clear
led_test(); // test leds
void led_test(){
strip.setPixelColor(0, clear_led); //clear led 0
strip.show();
strip.setPixelColor(0, red); strip.show();
delay(80);
strip.setPixelColor(0, clear_led); strip.show();
delay(30);
strip.setPixelColor(0, green); strip.show();
delay(80);
delay(30);
strip.setPixelColor(0, blue); strip.show();
delay(80);
delay(30);
strip.setPixelColor(0, white); strip.show();
delay(80);
Put your colors in an array and just manipulate the index into the array over time (e.g. with a Software Timer or some millis() logic).
thanks @ScruffR
I did like this… but I don’t know how to insert a delay using millis…
int color_patern1 [9];
delay(2000);
white = strip.Color(243, 63, 193); // White was (0,255,100) \\\violeta
//patern1
color_patern1 [0]=clear_led;
color_patern1 [1]=red;
color_patern1 [2]=clear_led;
color_patern1 [3]=green;
color_patern1 [4]=clear_led;
color_patern1 [5]=blue;
color_patern1 [6]=clear_led;
color_patern1 [7]=white;
color_patern1 [8]=clear_led;
//led_test();
led_patern1 () ;
void led_patern1 () {
uint8_t m;
for (m = 0; m < 9; m++) {
//unsigned long currentMillis = millis();
//if (currentMillis - previousMillis2 >= 200) {
strip.setPixelColor(0, color_patern1 [m]);
strip.show();
//previousMillis2 = currentMillis;
delay(200);
const uint32_t onTime = 80;
const uint32_t offTIme = 30;
const int color_off = strip.Color(0, 0, 0);
const int color_pattern[] = { strip.Color(255, 0, 0) // red
, strip.Color( 0, 255, 0) // green
, strip.Color( 0, 0, 255) // blue
, strip.Color(243, 63, 193) // white
const int countPattern = sizeof(color_pattern) / sizeof(color_pattern[0]);
strip.setPixelColor(0, color_off); // switch off
strip.show(); // Update all LEDs
led_patter();
void led_pattern() {
static uint32_t _ms = millis(); // to keep track of the timing
static bool _on = false; // to keep track of on or off state
static int _color = 0; // color to display
if (millis() - _ms < (_on ? onTime : offTime)) // not time to switch
return;
// now it's time, so lets go
_ms = millis; // restart timing
if (_on = !_on) { // toggle state and check current state
strip.setPixelColor(0, color_pattern[_color++]);
if(_color >= countPattern) // if required wrap round
_color = 0;
else {
strip.show();
thanks @ScruffR for your time and dedication helping rookies like me.
