Hello.
Why does this simple code freeze core after a few loop iterations? I see nothing except “38400” string (or some garbage on 57600 terminal speed) and led stop switching colors after few seconds.
RGB.control(true);
RGB.color(255, 255, 255);
Serial.begin(9600); // open serial over USB
while(!Serial.available()) SPARK_WLAN_Loop();
Serial1.begin(38400); // open Serial1 over TX and RX pins 38400 baud
delay(100);
Serial1.println("38400");
Serial1.end(); // close Serial1
delay(100);
Serial1.begin(57600); // open Serial1 over TX and RX pins 57600 baud
delay(100);
Serial1.println("57600");
RGB.color(255, 0, 0);
delay(1000);
Serial1.println("test");
RGB.color(0, 255, 0);
delay(1000);
Without changing baud rate to 57600 (Serial1.end(); Serial1.begin()) loop runs indefinitely and i see “test” strings in serial terminal on 38400 baud.
