Hi @Wraithan ,
Thank you for looking into this issue. Yes, please go ahead regarding th verbose logging. I have the Tachyon running on cellular connection.
Please let me know when you’re done. Let me know if you require any action from my side.
Hi @Wraithan ,
@zpm1066 I’ve fixed up your device, there appeared to be an issue with the local on disk files for our synchronization system. By removing them and it forced the device to rebuild it. I’m still trying to understand why that happened, but I’ve disabled the verbose logs and restarted particled to get it to take the configuration change.
Thanks for letting me use your device to understand what happened, it should be working as intended now.
Hi @Wraithan ,
Thank you! Tachyon now syncs with Particle Console.
Now seeing the Console ‘Last vitals’ and RSRP being in sync with particle-tachyon-ril-ctl vitals & cat /sys/class/power_supply/battery/capacity commands.
Very much appreciated!
Hi @Wraithan ,
The vitals information from the device to the cloud has stopped to synchronize again for some reason. The RSRP in Console > Networks has been stuck at -108 dBm, whereas running particle-tachyon-ril-ctl vitals gives RSRP that changes from -107 to -92 dBm.
I think, as before, you may need to force a rebuild of systemdoc that you use to synchronize the vitals information from the device to the cloud.
Appreciate if you could take a look. Thank you.
