Adam42
1
Hello Particle forum,
I’m experiencing degraded signal performance on 8.0-rc.11 as compared to 7.0
My setup uses a 1000uF cap inline with a 12V vin signal.
Connection on 7.0 is solid connection 95% of the time in 2 mins
Connection on 8.0-rc.11 is soild connection ~20% of the time.
I am using example 1 from the PublishQueueAsyncRK library
The connection issue on 8.0-rc.11 is much improved if I connect the battery. Unfortunately, our product does not run a battery.
I’m trying to understand what would show this performance difference between two firmware’s running the same software.
Could you try disabling charging in setup() with 0.8.0-rc.11? It might be related to this problem:
Adam42
3
Alright! Disabling charging has an improvement. The performance is similar to 7.0 again.
PMIC().disableCharging(); // Added to improve cell connection in 8.0
Serial.begin();
pinMode(ledPin, OUTPUT);
Thank you! @rickkas7!
