I would appreciate the community’s help on this basic question below. I have checked the forum for related topics but could not find the same topic.
I have an application where a softSerial port may receive data (40 bytes) while the Photon is processing sensor data inside a Sub (inside its loop()). I do not want to stop the processing in the Sub, but would like to process the data that came in via the softSerial port later.
What is the best way/s of doing so? Is it by using callbacks, interrupts, or simply checking after the Sub is done processing (if Serial(available) …)
Thanks in advance.
