Capacitance meter using the Photon
Hi @rocksetta
I recommend something like the LM358 op-amp, which is a very inexpensive component ($0.95 at Sparkfun):
In your circuit above, it goes on the yellow wire that feed inputs A0. There is another op-amp in the package so you can buffer another analog input if you need to.
