Hello, I am trying to add an authentication token to my github build for argon action and to do so I need an API User Token. The Particle wiki is making references to tabs in the Particle console that don't exist for me, specifically the Team tab. Any help would be appreciated. thank you.
API users are only available for products, and organizations for basic and enterprise users.
For products, including those on the free plan, API users can be created using the Team tab within the product. There are no API users at the sandbox level.
ok then I guess I'm not sure how to get the build for argon action to work. It worked at one point but the engineer who set it up is gone and I don't know how else to set it up.
It is possible that they created a regular user token using particle token create instead of an API user token.
Also if you are in a basic or enterprise organization, if your account does not have administration privileges, you won't see the Team tab in the organization.
that worked. that's exactly what i was looking for. thank you!
