What do you receive on the Arduino side?
What baudrate are you sending with?
I guess you are running out of free RX buffer space, since there is no handshaking in RX/TX communication.
If your Arduino can’t keep up with the speed you are sending data, you might end up with corrupted values.
A less likely scenario (due to the blocking default on the Electron side) would be that you are filling the TX buffer faster than it’ll be drained by sending the data across.
When I flash this code to two of my Photons, they can happily send your string either way
char msg[] = "{\"_id\": \"9wxtjvq3vcYmabyyf\", \"p0\": 1, \"p1\": 1, \"p2\": 1, \"p3\": 3, \"p4\": 3, \"p5\": 5, "
"\"p6\": 2.9, \"p7\": 3, \"p8\": 1, \"p9\": 1, \"p11\": 90, \"p12\": 80, \"p13\": 0, \"p14\": 21978.5, "
"\"p15\": 20500, \"p16\": 18000, \"p17\": 0, \"p18\": 21978.5, \"p19\": 20500, \"p20\": 18000, \"p21\": 0, "
"\"p22\": 21978.5, \"p23\": 20500, \"p24\": 18000, \"p31\": 5, \"p32\": 5, \"p33\": 45, \"p34\": 1, \"p44\": 90, "
"\"p81\": 5, \"p82\": 5, \"p83\": 2, \"p99\": 255, \"createdAt\": \"2016-07-20T08:19:57.466Z\", "
"\"deviceId\": \"23002a000951343334363138\", \"userId\": \"wzNvA38prEgWhtnsf\"}";
pinMode(D7, INPUT_PULLUP); // jumper D7 to GND to make one device the sender
Serial1.begin(115200);
if (digitalRead(D7))
{ // receiving device
Serial.begin(115200);
while(Serial1.available())
Serial.write(Serial1.read());
else
{ // sending device
Serial1.println(msg);
delay(10);
