I’ve just started using @harrisonhjones’s “LEDEffect” library as I wanted to be able to easily set LEDs to blink or breathe without dealing with a lot of millis timers etc in my loop.
Now I’ve got the absolute darndest problem that I CANNOT figure out. It’s nearly midnight here and that might have something to do with it.
One of my LEDs just WILL not function - AT ALL - with this code. I’ve tried moving the pin assignment about, the problem follows this particular LED (i.e. it doesn’t light).
However, if I either
a) leave wiring wholly intact BUT roll back to previous code before I involved this library, the LED functions as before (so it can’t be a problematic I/O pin?
b) if I connect the LED directly to the Photon’s gnd and 3.3v it lights.
I’m guessing I’ve made an error somewhere in the code, but I removed everything from my loop except “OfficeLED.on();” and STILL it didn’t work. I had a brainwave and wondered if it was because I’d come up against a programmed in limit for number of LEDs the library is default configured to deal with but can find no evidence for this in the library files. And I moved the declaration of the problematic pin from last to first. Nothing changed. HELP!!
P.S. I am SURE this will turn out to be something (in my code? it must be!) rather than a @harrisonhjones bug by the way…
#include "Alert.h"
#include "JC_Button.h"
#include <LEDEffect.h>
using namespace Alert;
SYSTEM_THREAD(ENABLED);
// PUB-SUB constants
constexpr char * DEVICE_NAME = "ALERT";
constexpr char * WINDOWSHUT_MSSG = "Office window shut.";
constexpr char * WINDOWOPEN_MSSG = "Office window open.";
constexpr char * BWINDOWSHUT_MSSG = "Bathroom window shut.";
constexpr char * BWINDOWOPEN_MSSG = "Bathroom window open.";
constexpr char * BDSHUT_MSSG = "Bathroom door shut.";
constexpr char * BDOPEN_MSSG = "Bathroom door open.";
constexpr char * SDCLOSED_MSSG = "Sliding door closed.";
constexpr char * SDOPEN_MSSG = "Sliding door open.";
constexpr char * KEEPBOLT_MSSG = "Stores door locked.";
constexpr char * KEEPOPEN_MSSG = "Stores door unlocked.";
constexpr char * MDKEEPBOLT_MSSG = "Main door locked.";
constexpr char * MDKEEPOPEN_MSSG = "Main door unlocked.";
constexpr char * RSATUS_MSSG = "Requesting Status";
constexpr char * SHOPL_MSSG = "SHOPLIFTER";
constexpr char * RESCUE_MSSG = "RESCUE";
constexpr char * RAIN_MSSG = "RAIN";
int slidingstate = 3;
int Storeskeepstate = 3;
int officewindowlocked = 3;
int bathroomwindowlocked = 3;
int maindoorlocked = 3;
LEDEffect BathroomLED(D3); //should be D3
LEDEffect OfficeLED(D4); //should be D4
LEDEffect SlidingLED(D0); //Should be D0
LEDEffect StoresLED(D1); //should be D1
LEDEffect MainLED(D2); //should be D2
// function declarations
void eventHandler(const char * event,
const char * data);
#include "DFRobotDFPlayerMini.h"
#include "TimeAlarms/TimeAlarms.h"
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
boolean alreadyRun = false;
Particle.subscribe(DEVICE_NAME, eventHandler, MY_DEVICES);
setZone();
Particle.function("slstate", setSlidingState);
Particle.function("cvstate", setStoresState);
Particle.function("mnstate", setMainState);
Particle.function("ofstate", setOfficeState);
Particle.function("btstate", setBathState);
Alarm.alarmRepeat(8, 1, 00, setZone);
Serial1.begin(9600);
if (!myDFPlayer.begin(Serial1)) { // use Serial1 to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while (true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
//----Set volume----
myDFPlayer.volume(30); //Set volume value (0~30).
myDFPlayer.volumeUp(); //Volume Up
myDFPlayer.volumeDown(); //Volume Down
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
//----Set device we use SD as default----
// myDFPlayer.outputDevice(DFPLAYER_DEVICE_U_DISK);
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
//----Read imformation----
Serial.println(myDFPlayer.readState()); //read mp3 state
Serial.println(myDFPlayer.readVolume()); //read current volume
Serial.println(myDFPlayer.readEQ()); //read EQ setting
Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read fill counts in folder SD:/03
if (alreadyRun == false) {
InitialPub();
SlidingLED.update();
StoresLED.update();
BathroomLED.update();
OfficeLED.update();
MainLED.update();
ToggleSwitchAction::update();
//digitalClockDisplay();
MillisTimer::processTimers();
Alarm.delay(0); // wait one second between clock display
static unsigned long timer = millis();
if (millis() - timer > 3000) {
timer = millis();
if (myDFPlayer.available()) {
printDetail(myDFPlayer.readType(), myDFPlayer.read());
if (Time.hour() >= 8 || Time.hour() < 16) //time between 0800 and 1500
if (Storeskeepstate == 0) {
StoresLED.blink(125);
} else {
StoresLED.off();
if (slidingstate == 0) {
SlidingLED.blink(125);
} else {
SlidingLED.off();
if (Time.hour() >= 17 || Time.hour() <= 23) {
if (bathroomwindowlocked == 0) {
BathroomLED.breath(30);
} else {
BathroomLED.blink(125);
StoresLED.breath(30);
} else {
SlidingLED.breath(30);
} else {
if (maindoorlocked == 0) {
MainLED.breath(30);
} else {
MainLED.blink(125);
if (officewindowlocked == 0) {
OfficeLED.breath(30);
} else {
OfficeLED.blink(125);
// functions to be called when an alarm triggers:
void Repeats() {
Serial.println("15 second timer");
void printDetail(uint8_t type, int value) {
switch (type) {
case TimeOut:
Serial.println(F("Time Out!"));
break;
case WrongStack:
Serial.println(F("Stack Wrong!"));
break;
case DFPlayerCardInserted:
Serial.println(F("Card Inserted!"));
break;
case DFPlayerCardRemoved:
Serial.println(F("Card Removed!"));
break;
case DFPlayerCardOnline:
Serial.println(F("Card Online!"));
break;
case DFPlayerPlayFinished:
Serial.print(F("Number:"));
Serial.print(value);
Serial.println(F(" Play Finished!"));
break;
case DFPlayerError:
Serial.print(F("DFPlayerError:"));
switch (value) {
case Busy:
Serial.println(F("Card not found"));
break;
case Sleeping:
Serial.println(F("Sleeping"));
break;
case SerialWrongStack:
Serial.println(F("Get Wrong Stack"));
break;
case CheckSumNotMatch:
Serial.println(F("Check Sum Not Match"));
break;
case FileIndexOut:
Serial.println(F("File Index Out of Bound"));
break;
case FileMismatch:
Serial.println(F("Cannot Find File"));
break;
case Advertise:
Serial.println(F("In Advertise"));
break;
default:
break;
break;
default:
break;
void digitalClockDisplay() {
// digital clock display of the time
Serial.print(Time.hour());
printDigits(Time.minute());
printDigits(Time.second());
Serial.println();
void printDigits(int digits) {
Serial.print(":");
if (digits < 10)
Serial.print('0');
Serial.print(digits);
const char * data) {
if (strcmp(data, SHOPL_MSSG) == 0) {
myDFPlayer.playMp3Folder(1);
} else if (strcmp(data, RESCUE_MSSG) == 0) {
myDFPlayer.playMp3Folder(4);
} else if (strcmp(data, RAIN_MSSG) == 0) {
myDFPlayer.playMp3Folder(20);
} else if (strcmp(data, MDKEEPOPEN_MSSG) == 0) {
maindoorlocked = 1;
} else if (strcmp(data, MDKEEPBOLT_MSSG) == 0) {
maindoorlocked = 0;
} else if (strcmp(data, SDOPEN_MSSG) == 0) {
slidingstate = 1;
} else if (strcmp(data, SDCLOSED_MSSG) == 0) {
slidingstate = 0;
} else if (strcmp(data, KEEPOPEN_MSSG) == 0) {
Storeskeepstate = 1;
} else if (strcmp(data, KEEPBOLT_MSSG) == 0) {
Storeskeepstate = 0;
} else if (strcmp(data, BWINDOWOPEN_MSSG) == 0) {
bathroomwindowlocked = 1;
} else if (strcmp(data, BWINDOWSHUT_MSSG) == 0) {
bathroomwindowlocked = 0;
} else if (strcmp(data, WINDOWOPEN_MSSG) == 0) {
officewindowlocked = 1;
} else if (strcmp(data, WINDOWSHUT_MSSG) == 0) {
officewindowlocked = 0;
sscanf(data, "K%d, S%d", & slidingstate, & Storeskeepstate);
sscanf(data, "O%d, B%d", & officewindowlocked, & bathroomwindowlocked);
void setZone() {
Particle.syncTime();
int month = Time.month();
int day = Time.day();
int weekday = Time.weekday();
int previousSunday = day - weekday + 1;
if (month < 3 || month > 11) {
Time.zone(0);
} else if (month > 3 && month < 11) {
Time.zone(1);
} else if (month == 3) {
int offset = (previousSunday >= 8) ? 1 : 0;
Time.zone(offset);
} else {
int offset = (previousSunday <= 0) ? 1 : 0;
Time.zone(offset);
void InitialPub() {
Particle.publish(DEVICE_NAME, RSATUS_MSSG, 60, PRIVATE);
alreadyRun = true;
int setSlidingState(String s) {
slidingstate = atoi(s);
return slidingstate;
int setBathState(String s) {
bathroomwindowlocked = atoi(s);
return bathroomwindowlocked;
int setOfficeState(String s) {
officewindowlocked = atoi(s);
return officewindowlocked;
int setMainState(String s) {
maindoorlocked = atoi(s);
return maindoorlocked;
int setStoresState(String s) {
Storeskeepstate = atoi(s);
return Storeskeepstate;
Really sorry about the big dump of code. I figured if it was a small segment of my code I’d be told to post the whole lot and I figure I might be criticised now for either not including the library files OR for posting irrelevant chunks of my ino file. Sorry either way!
